VR Tuned ECU Tuning Box Ford Ranger Raptor 3.0L EcoBoost 405HP
Fred
It's just a rebranded RaceChip. Extremely low resale when you realize how junk these systems are. If you want a proper piggyback a JB4 is the way to go.
Bonus Oz
Bruce
Cairns Australia
23 Raptor , 72 Escort RS , 89 Sierra Cosworth , 60 Mini Cooper, 72 Mini Hayabusa
Wheeler Dealer
I had the JB4 fitted for a couple of months before I had it flashed.
never had it on a dyno when fitted but the difference from a mass produced piggyback was impressive.
only negative from me was it was a little lean on the higher maps than I run normally and under full load my AFR warning was going off .
JustNick
Nick
BatonRouge
Shelter Green Ranger Raptor
Engineering Project Manager
Can confirm about going with a JB4 instead. I had one on my A6 and their customer service was out of this world. George over there was extremely patient with me dialing in my Map 6 on E30 over the course of a couple of months
moproblems
SW MI
From everything I see that's the issue with these trucks. Not enough fuel to keep up. Most flashes only add 3lbs of boost but add a ton of timing and fuel. Piggybacks can't really adjust fueling outside of short term and long term trims via data manipulation.
Bonus Oz
Bruce
Cairns Australia
Wheeler Dealer
It is an issue but it’s not just these trucks , all stock turbo vehicles run injectors just large enough to cope and fuel pressure behind them also at just enough pressure.
I’m experimenting at the moment with fueling , larger injectors and higher fuel pressures to try and max out the stock turbos to see what they can actually achieve.
I’ve just upgraded the fuel system in my escort which now runs a surge tank alongside the main tank with a low pressure pump to feed the surge tank then 2 big Bosch 44 high pressure pumps to feed the fuel line .
it also runs a high pressure fuel pressure regulator and now 1200cc injectors.
im happy with that set up and I doubt the raptor will ever need it to this degree but a scaled down set up is on the cards.
Ford Ranger VR Tuned ECU Tuning Box Ford Ranger Raptor 3.0L EcoBoost 405HP IMG_0155
Ford Ranger VR Tuned ECU Tuning Box Ford Ranger Raptor 3.0L EcoBoost 405HP IMG_0150
Ford Ranger VR Tuned ECU Tuning Box Ford Ranger Raptor 3.0L EcoBoost 405HP IMG_0143
HyperM3
Lawrenceville, NJ
Been seriously debating on going the JB4 route. Ive had them on 3 vehicles in the past with no issues and only smiles.
OH3Cobra
JP
Indy
Sales
Bonus OZ that is a clean machine. Love the attention to detail
Bonus Oz
Bruce
Cairns Australia
Wheeler Dealer
Thank you .
old girl goes well for 52 years old
RANGER/HOBB
THE WORLD
Retired USAF
Vivid Racing has been producing the VR Tuner for more than a decade. I’ve run one on a GLA45 AMG and an Audi TTRS and wasn’t made in Germany by DTS or Race Chips.
JB4 is a piggyback tuner just like the are generic for several models, for one tuner. Not specific to one model. Both are nothing but “sensor foolers.“
However, the JB4 is more expensive and utilizes the same tuner for the 2.3L. It’s no better or worse than the VR Tuner.🤣👍🇺🇸
