SLJ
The Finger Lakes
Do you have the 2.3L or the 2.7L? The 2.7L seems to not really struggle even in the mountains (TN Smokeys) while towing.
I had no problem pulling with the Maverick 2.0/8 speed w/4K tow package in the Smokeys so the 2.3 Ranger w/tow package should be fine.
Ford Ranger What are you towing with your 6th Gen Ranger? smokies
rikairving
Rik
Old Town, Fi
ā€˜25 Desert Sand Ranger XLT, FX4. ā€˜13 F150 XLT SC, 3.5 EB.
Retired sys/mech/elec eng.
Have towed a 6x12 x 4k lb box several thousand miles last summer with the 2.3MPC motor; absolutely not starved for power or stability. The early torque onset, as well as the gearing and transmission do their job well. Did runs from Florida to Maine, and back through Kentucky and Tennessee, and my only observance was the oil temp gets elevated when the motor is in boost for extended lengths of time, such as a mountain climb. And of note, power is not free, mileage was around 15 or less mpg at highway speeds with that boxy sail behind me. I am normally hovering around 25 mpg with regular driving. I also tow a small teardrop camper, and the truck doesn’t even know it’s there, with maybe a 1 mpg loss in fuel economy.
Have the non-advanced tow package, and use a Curt echo as a TBC, and it works well. You don’t need the phone running once it is set up. It is limited however that you need your phone app open to run just the trailer brakes manually. Have just changed to a hardwired plug and play TBC solution from Amazon. Will post on my setup and testing later.
Photo is my dad’s camper with my truck a few weeks ago. His truck was down waiting on parts, so used mine to get his camper to and from the reserved weekend getaway, 65 miles each way. Trailer is 21’, and used a Husky WDH that he normally uses on his F150. No changes on setup, just put his hitch directly into my receiver. Camper is about 6K lbs loaded, and had three adults and a dog in the truck.
No power issues, or stability problems with passing trucks. Setup is solid, as is the truck.
Kept the rig at 60 mph or below on the highway, most of the time in 8th gear, with occasional 9th runs on flat ground at 60 mph. There was plenty of headroom to go faster, but fuel consumption goes up exponentially as speed increases! Frontal area and a flat trailer back end make highway speeds expensive. That little gas tank empties quick! 60 mph was between 11 and 12 mpg.
Around town and back roads truck was much more economical; 18 to 20 mpg, with a light foot.
This was a one time thing, and if I was going to do this all the time would go for the 2.7 v6 for the better power band, and maybe less work for the motor.
I have towed all kinds of rigs since the 70’s, bigger setups with much larger motors, but with not nearly the power these new motors and transmissions output. Mileage isn’t any better though, power isn’t free!
Also, these Rangers aren’t that small anymore. My mid 70’s full sized 3/4 ton trucks were about the same size. That said, the running gear was heavier, but the brakes weren’t!
Ford Ranger What are you towing with your 6th Gen Ranger? IMG_1032
Harris64
Glen
US
2024 Ford Ranger XLT FX4
Paramedic
2024 Ranger XLT FX4 with 2.3 with Trailer Tow Package (the one without the trailer brake controller)
Blue Ox Track Pro WDH
Redarc Tow-Pro Link Bluetooth Brake Controller
Pulling a 2022 Cherokee Grey Wolf 20RDSE
25'4" length
10'4" height
4331# dry loaded to 5200#
I traveled with my wife & the 116# from Cambridge, Maryland to Nashville, Tennessee & back hopscotching through the Smokey Mountains. I never lacked power & no trailer sway as long as you keep it reasonable before 70m.p.h. My biggest problem was keeping premium fuel in the tank. I was averaging 11 m.p.g.
Ford Ranger What are you towing with your 6th Gen Ranger? 20260729_122018
Ford Ranger What are you towing with your 6th Gen Ranger? 20260726_084408
Ford Ranger What are you towing with your 6th Gen Ranger? 20260531_083439
Ford Ranger What are you towing with your 6th Gen Ranger? 20260720_210006
Ford Ranger What are you towing with your 6th Gen Ranger? 20260719_080035
Ford Ranger What are you towing with your 6th Gen Ranger? 20260712_140446
cb4017
Cliff
Northern NV
2026 XLT 2.7L FX4
This Rpod is what I've been towing. About 3,500 GVRW. Truck does a great job hauling it.
Ford Ranger What are you towing with your 6th Gen Ranger? 20260823_191822
SnyperX
Mark
Wisconsin
I am towing the following setup. Had 2 adults and 2 dogs in the truck at like 570 lbs with about 100 lbs of gear in the bed.
TV: 2024 Ford Ranger, adv. tow pkg, 2.3L, UGR oil catch can
Trailer: 2026 Rockwood Mini Lite 2109S
Hitch: Haul-Master 10,000 lb. WDH with sway bar kit
Suspension: Timbren SES springs with Bilstein 5100 shocks in rear
Front Brakes: Dynamic Friction GeoMet rotors with Power Stop Z36 pads
Speed was 60-65mph with about 9 mpg on 87 octane.
Ford Ranger What are you towing with your 6th Gen Ranger? 2109S
I towed my PJ utility trailer the other day.
I think that was the first time I towed with one of my RRs.
Pulls it like it is not even back there.
Probably should since it doesn't really weigh all that much.
Ford Ranger What are you towing with your 6th Gen Ranger? IMG_6528
Ford Ranger What are you towing with your 6th Gen Ranger? IMG_6527
Ford Ranger What are you towing with your 6th Gen Ranger? IMG_6529
SLJ
The Finger Lakes
On the way home from the Adirondacks on a rainy day today...
Ford Ranger What are you towing with your 6th Gen Ranger? camper
