Towing fuel economy... What are you getting?
johnvosh
Johnathan
Stony Plain, AB
2026 Ford Ranger Lariat 2.7L
Warehouse Supervisor/ Health & Safety
Well after 3 trips with my new truck towing my trailer, I am quite happy with it! It pulls better than the 2.3L in my 2023 truck and the fuel economy towing seems to be a tick better as well. While towing I tend to keep my speed between 90-100 KM/H. I keep 10th locked out and depending on how's it going I will sometimes lock out 9th as well, otherwise I just let it do it's thing. I do run premium in my truck at all times usually. Either 91, 93, or 94 octane depending on the station I stop at. I don't use the computer reading as it is always off, saying I'm getting better than what I actually am getting. The truck bed carries the trailer spare tire, 2x 20lb propane tanks, some firewood, griddle, small BBQ, folding table. The trailer tongue with full water is a bit over 600lb and pulls quite good with a full tank. Trailer is just a small 16ft with a gvwr of 4,000 lbs.
1st trip -> Heading west, no water in tank I got 20.2 L/100 KM; 5.0 KM/L; 11.7 MPG. Heading west from my place to the campground you are increasing in elevation from around 2326 FT to 3020 FT. Heading back east I got 16.6 L/100 KM; 6.0KM/L; 14.2 MPG
2nd trip -> I didn't fuel up before/after as it was close to home and only used about a 1/4 tank, so it was probably around 10 MPG; 23.52L/100 KM; 4.25 KM/L
3rd trip -> Heading east, 40 gallons water in tank I got 21.3L/100 KM; 4.7KM/L; 11.1 MPG and coming back west I was fighting a wind the entire way so got 22.3L/100 KM; 4.5KM/L; 10.5 MPG. I kept the truck in 8th gear both ways as there are quite a few hills and quite a few jogs in the road requiring you to stop, turn and then accelerate again.
I have a trip to BC coming in September so it will be interesting to see what I get for fuel usage. I will be travelling with no water in the tank as the campground I'm going to is full service. Will be about 1300 KM's round trip!
What is everyone else getting for fuel economy while towing?
Sharpie223
E.Wa
In-between atm
Not quite the same level of towing as a commercially built camper, but pulling a teardrop built to approximately roof height of the truck, I get ~20 mpg. The weight is probably less than 1000 lbs loaded and tongue weight is somewhere between 100-150 lbs. The back is a shallower slope than the typical teardrop, more aerodynamic, but I think the air coming off the cab crashes into the flat front and is where most of my mpg loss comes from (averaging 26mpg daily driving). Once I get a canopy I expect the towing mpg to be better. 2.7 running any kind of fuel, 87 vs 93 has made no difference for me.
I got about 17 mpg towing a 2000lb boat+trailer locally, hard to say what it would be on a longer trip with less stop and go.
Edit: this is based on the built in mpg display. With the current tank I am working to come up with a correction factor. So far I know that the odometer is about dead on, so I won't need to correct for actual vs measured distance. We'll see how much I need to correct for actual vs measured fuel consumption when I fill up at the end of the week.
mattmico
Winston Salem, NC USA
‘24 Ford Ranger Lariat FX4
Self Employed
We tow our 17’ Winnebago micro Minnie, about 4300lbs loaded with our ‘24 Lariat FX4 with adv tow pkg all thru the Appalachian mountains in NC and up to Maryland. The average has been 12 mpg.
ADVNTURR
Cleveland, OH
I've done a few tows with my '24 2.7L
Borrowed open aluminum trailer (~5000lb total) from OH to KY with cruise set around 70mph and I was getting 12-13mpg
Ford Ranger Towing fuel economy... What are you getting? PXL_20241022_223339646
My open aluminum trailer with tire rack and stone guard (~5000lb total) from OH to PA with cruise set around 70mph and I was getting 11-12mpg
Ford Ranger Towing fuel economy... What are you getting? PXL_20250503_210311092
srv256ss
2025 Ford Ranger Raptor
My Raptor was getting 14 mpg between Atlanta and Knoxville.
chasc
Illinois
2024 Ranger
I'm curious what motivates you to manually lock out 9th and 10th gear? I've pulled a 20 ft travel trailer in a lot of conditions and I think the only time I felt compelled to use lockout was when I wanted a touch more engine braking coming down a pass in CO. Usually with no override it stays in 9th gear on the interstate on its own, unless you're going downhill or have an awesome tail wind.
[EDIT] I don't think you said: Do you use the Towing driving mode? That makes a noticeable difference too.
I also have a 2.7L Lariat and I pull a 20 ft travel trailer with a height about 9.7 ft. We don't often exceed 65 MPH in highway driving. I'm very pleased if we're getting 15 MPG. 12 – 14 MPG is common if weather isn't perfect or you're gaining elevation. I don't typically see less than 10 MPG even in the worst headwind I'm comfortable towing in. Greater than 15 MPG I've only seen on long slow sections where I'm doing 30-40 MPH.
johnvosh
johnvosh
Johnathan
Stony Plain, AB
When I am towing I always use the tow mode and then I'll usually put the instant fuel economy display in the centre. On my most recent trip heading to Westcove campground (north of St.Paul, AB) I let it go into 9th for the 1st bit and then I put it down to 8th and even though the RPM was sitting about 400RPM higher, the fuel economy was actually a bit better according to the gauge on the screen. When I was coming back home I was fighting a wind the entire time so just kept in 8th gear to keep it more in the power instead of going back and forth between 9th and 8th.
The only reason I stick to around 100 KM/H (62MPH) is for better fuel economy. I'm also usually not in a hurry when I'm going camping and make sure to leave extra time. If people are in a hurry they can go around.
My dad tows a 26ft tandem axle trailer with a 2019 Ford Expedition Max and the 3.5L and he will tow up to around 113 KM/H and he averages only about 8MPG!
HotPepperLariat
Rod
Appomattox Virginia
VW Touareg
On a 5,000 mile trip from Virginia to west Texas (Big Bend NP) towing our 17' Casita (2,400# dry) my '24 Lariat 4X2 with the 2.3 averaged 16.1mpg in Tow mode. That was hand calculated. I generally kept it between 60 and 65mph for safety and economy concerns. Besides we're retired so what's the rush???
Ford Ranger Towing fuel economy... What are you getting? DSC_0989
some_guy
some
florida
entrepreneur
RR towing a total load 2000lb trailer faster than i should have [70mph] i was getting 14-15mpg. pretty decent i think
Satex
Blake
San Antonio
2024 Ranger 2.7 Ecoboost
Towing a 2025 NuCamp T@B 400 Boondock with the 2.3L I get anywhere from 11.3-13.1mpg. Usually lower than higher.
That's similar to my mpg... Same camper, except ours is a 2022. Our truck has the 2.7 liter. We typically run 60 to 65 mph while towing.
David Wagner
Maryland USA
Hi, 2025 Lariat 2.7 w/advance tow package towing 23Ft Airstream, 4,600 Lbs Dry about 5,600 loaded. I've towed a little over 4,000 miles so far, virtually all on flat land east-coast Interstate hwys. Always in tow-mode and 91/93 octane gas and usually around 60, maybe up to 65 mph. I get right at 15 mpg (from the dashboard computer but seems about right). I go very light on the gas pedal, even when starting out, so that helps. I know it will drop down once I get to the real mountains out in western US... I used to have a motorhome that never got better than 8 mpg so I am really loving the Ranger at 15...
Also, one other item is I recently got mirror extensions that I think are real nice, from Amazzn -- K Source # 81870 for 2024+ Ranger. The Airstream is a full 8ft wide and the factory mirrors are not enough for me to back up with so these just "clip on" right over your factory mirror without scratching the paint, don't vibrate, you still have all your mirror turn signals and for my 2 cents are well worth the $90...
Regards...
Dave8311
2025 Ford Ranger XLT
We are close to completing this trip, about 3 day left before we are home.
Ford Ranger Towing fuel economy... What are you getting? Screenshot 2026-08-18 100611
We are pulling this trailer which weighs around 6,000 lbs.
Ford Ranger Towing fuel economy... What are you getting? PXL_20260718_210541227
2025 XLT with 2.3 driving around 65 mph the average has been right around 10.5 MPG
The only complaints on this trip using this Ranger as a tow vehicle is the slop in the hitch receiver and the gas tank is too small.
Wayfaring Ranger
STL
Lately I've been keeping it right at 70mph just so the 65-68mph governed semis don't have to pass me on the two lane highways.
David Wagner
Maryland USA
[QUOTE="Dave8311, post: 479475
[/QUOTE]
Try a "hitch anti-rattle and stabilizer" from Etrailer #99007 about $40 and makes a real difference...
