What's the best way to take this hose off
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
Does the hose fit over a barb? Wasn't sure if walking it off with a thin thickness/medium width flathead is feasible
JrHDRanger
Indiana
If it’s just the hose itself you need to remove use a heat gun, it will slip right off.
JrHDRanger
Indiana
Pretty sure you need a special ford tool to remove that.
Scooter
Vancouver, BC, Canada
65 Comet, 2011 Ford Ranger
--Machinist
What does it do. Reason for wishing to take it off. A side picture would be helpful.
I would say try to figure out what type of connection system is used.
The way the cover look's the heat gun could help to loosen cover. Maybe the cover will roll up.
Look to see if you can get the part first.
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
Is it the horizontal hose portion that needing to be removed or the what looks like a 90 degree elbow that needs removal along with the hose?
MotternTv
MotternTv
Cody
Harrod Ohio
The 90 with the hose, I want to be able to put on the Clean Side Separator I got with my Dual catch can
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
Could be using the AC line quick disconnect, I know the tool does need certain clearance though to slip below and inside those type of connectors. I had to release 2 for air intake and dual catch can
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
I remember watching that video and it's well done, I feel destroying the fitting as shown does seem a bit wasteful but also it's odd that the clearance to access with a ac quick disconnect tool is so non existent from factory
sweeks888
Richland, WA
Agreed, I was dismayed at having to clip the sides of these connectors. I believe a tool does exist, but must be cost prohibitive, at least from Ford. I wonder if a cheaper one is available from say Amazon or eBay for this type connector.
Too late now for me, as I've already installed the IAG unit and working quite well (near as I can tell, at least no noticeable issues thus far).
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
IAG seems to make very good products. AFR in their CAI instructions explained the options but I can say with confidence a entire AC line quick disconnect tool kit ca be purchased cheaper than one replacement connector. The reason I wanted to preserve all connectors is to put back stock parts for smog if needed...
