Wheel offsets for 2024+ Ranger Raptor?
MidnightBlue
Ford Ranger
I've been searching for aftermarket wheels for RR which is +55mm and pretty limited on options.
With the fox suspension being so dialed I'm just wondering how changing to an offset like +25 or 0 would affect damper performance?
To clarify is it more important to keep a relatively close offset and wheel weight to stock versus a normal suspension?
CodeOrangeUAE
LUKE
Abu dhabi
Ranger raptor 2024
Looking for the same info.
Looking at +25 with the 285/70R17 tyres but cant tell if they will rub or not when at max turnand max compression....
I’m thinking based on the pics and video i have seen of the Oem rims on the RR, that the +20 or +25 should be about right to get them flush with fender extension.
They look like they are counter sunk up under the body or inside the fender extension by around 3/4 to an inch +25 mm vs +55 should work out to about an inch.
‘I am also thinking I want to try and bump the tire size from 33 to 34.
MidnightBlue
MidnightBlue
Ford Ranger
The look like they are counter sunk up under the body or inside the fender extension by around 3/4 to an inch +25 mm vs +55 should work out to about an inch.
Thanks and I agree. I want to keep the offset change minimal so the wheels are flush with fenders but I think +35 would be just flush and +25 would be slight poke. Hard to say without proper measurements.
Be interesting to see peoples aftermarket wheel choices.
You may be very well correct on that. Finding a +35 I am afraid will be a very difficult find.
Anyone know what the Bronco SAS wheel is in terms of offset. Also just guessing the Bronco uses the same bolt pattern. I had given some thought to using the Bronco Rims to get a little more offset.
I do like the looks of my Bronco Rims better than the RR rims.
Maybe or likely would need to drop the tire size down to say a 34" tire.
Ford Ranger Wheel offsets for 2024+ Ranger Raptor? img_7410-jpe
Do you happen to have the full spec of the RR rims.
+55 is that a 17x8.5 rim or 17x9 , 17x8?
The OEM Tire is 285/70 R17
I am thinking 305/70 R17 is what I would like to try and run on my RR whenever I get it.
I am hoping I can clear it and find a decent looking wheel in a +30 to +40 offset.
Ford Ranger Wheel offsets for 2024+ Ranger Raptor? 1710876426913-20
MidnightBlue
MidnightBlue
Ford Ranger
I talked to a few aussies about this who have their trucks.
The stock wheel is 17x8.5 +55
At +25 it will give you just under an inch of poke. +35 would be about flush with fenders depending on wheel width.
For tires a 35” will work on the back stock but will rub on the front fenders at full lock even with a 2-3” lift. With some cutting it will be driveable but not ideal on this truck. Alternatively you can drop to a negative offset but it’s crazy poke.
I would say 305/70 should clear at +35 and work better without creating all the issues 35’s do. Hard to say till we get our trucks.
T-Rev
Does anyone have the bronco Sasquatch wheel‘s offset. Just guessing it might be close to the +35 I am looking for.
3wheelkhalil
Khalil
Atlanta, GA
I am hoping that +25 is a perfect complement to a RR, as I have a set of Method MR318s from my Bronco in Gloss Black that I want to swap over to the RR when it is time.
RapVillin
Tacoma
business owner
Following....want matte bronze 20" with ko3 with zero poke. But damn if it's not impossible to find
I found the spec of the 17” Bronco SAS wheel. It’s a +30
i like the looks just hate the RR +55 offset.
Item specifics
Condition
Used
Seller Notes
“LOW MILE TAKE OFFS - FREE SHIPPING - FULL SIZE Bronco”
Brand
Ford
Rim Material
Aluminum
Color
Gray
Rim Width
8.5
Manufacturer Part Number
BroncoNTO
Quantity
Rim Diameter
Bolt Pattern
6x139.7
Wheel Material
Aluminum
Wheel Construction
One Piece Cast
Offset
+30
Acesraptor
Asa
UK
3.0 V6 RR
Property
I run KMC impact 17x9 +18ET with 315/70/17 KO2's. There is rub on roughly 3/4 lock but not on 1/2 and full lock so its tight... Trying to find someone to fit the Eibach pro lift kit here in the UK as I'm told spring swaps on a raptor is a bit of a nightmare...
