Windshield is there no molding/gasket
Loudpa
Just noticed that the windshield sort of floats meaning no surrounding molding beyond the very botton. Can I assume this is normal as I dont have another Ranger to compare with.
Ford Ranger Windshield is there no molding/gasket Windshield2
Ford Ranger Windshield is there no molding/gasket Windshield1
Yes normal my previous vehicle was like that too.
Yup. Also let's sand and junk build up in the lower corners and cause rust/corrosion.
Bruce
Bruce
Minnesota
Do a search on Ford Motor Company assembly --- and you will see that the windshield frame is spread with Chauk by a robot, and then a robot installs the glass. So, you hope that the first robot does its job correctly.
got3fords
James
Central Va.
caulk?
Sharpie223
E.Wa
In-between atm
The urethane adhesive used to install windshields is going to be much more leak tight than any trim/seal. But if you prefer the trimmed-out look, it shouldn't be too hard to find a suitable roll of automotive trim.
Loudpa
Loudpa
Good to know as I was curious about it and just in case it was left off at factory.
My old BMW E39 has a cosmetic seal as well and it being a 1999 has all but dried up and fallen off but it was there.
Bruce
Bruce
Minnesota
Hey....................I been reading replies here for months -- when does spelling count?
When keyboards get normal sized. Phone keyboards stuck to type properly on
Ha ha ha
