Installed some Redline hood struts on one of my RRs yesterday.
‘Curious if the added structure will help or improve my hood flutter that I have on this one.
Ford Ranger What did you do to your Ranger Raptor Today? IMG_6259
Ford Ranger What did you do to your Ranger Raptor Today? IMG_6260
Ford Ranger What did you do to your Ranger Raptor Today? IMG_6261
JJT
JAVIER
SPAIN
RAPTOR 3.0
Does anyone know whether the hood on the US-spec Ranger Raptor is aluminum or steel? I'm trying to confirm the material. Thanks
JJT
JAVIER
SPAIN
RAPTOR 3.0
Fridge magnets are your friend when it comes to things like that.
Thanks! I know a magnet would work. The European-spec Ranger Raptor has a steel hood, not aluminum. I'm just trying to find out if Ford used a different material for the US-spec version.
Peter949
Peter
Irvine, CA
Was planning to wait for those until I found same size Toyos cheap. Your setup rub in full lock reverse? Jumps? Mine barely rubs on full lock reverse and hits the wheel well a little on jumps.
Ford Performance 703’s and 35x11.5 KO3’s installed.
Aluminum hood but fenders are steel.
From high speed or rough road? I did not notice anything at 130km/h (80mph)
My 24 RR is solid no hood shake , my white 25 is the one with the hood flutter, and no matter how I adjust the rubber hood stoppers I can’t seem to get it to fit like my 24.
I drove my black 25 also recently and not seen any hood flutter in that one either.But that truck only has around 300 miles on it. Jury is still a little out on that one.
Issue seems very hit and miss with these trucks.
Would love to know if anyone with the flutter ever found a way to stop it.
‘Was in that truck with flutter today for 3 hours out on the interstate running 80-90 mph, the hood struts made no difference at all, still flutters in the wind. Especially bounces around when passing semi trucks when you get in that dirty air .
STEVE_K
Snohomish, WA
Ah! Didn't notice your profile had you listed in Spain!
Reactions: JJT
dpAtlanta
Just North of Atlanta
My Ranger Raptor & my Bronco hoods both flutter.
And they are both aluminum.
In fact, every panel on the Bronco is aluminum except for the rear quarters.
OxygenMask
Phil
Eugene, Oregon
Mine is alyoominium. My Route 66 fridge magnet fell off....
OxygenMask
Phil
Eugene, Oregon
In the desert southwest on super windy days wind gusts could do it.
Otherwise oncoming semis make it look like it might fly off!
yoopercharged
I’ve got a 2” front spacer. No rubbing in forward or reverse. I did have the truck airborne over the weekend and didn’t rub anywhere. OEM crash bars and splash guards in place and untrimmed. Visually, it does look like a large compression event with the wheel turned sharply could rub on the crash bars, but I don’t foresee that ever occurring with my use case.
Ford Ranger What did you do to your Ranger Raptor Today? IMG_9673
