1st trailer hookup, how’s it look?
johnvosh
johnvosh
Johnathan
Stony Plain, AB
2026 Ford Ranger Lariat 2.7L
Warehouse Supervisor/ Health & Safety
Sorry about delay in replying, haven’t had much time since been busy with the nieces and camping. We had a spare ball hitch laying around at work so I decided to install that and see if it would help at all. It raised it a good 1-1.5 inches from the hitch I was using. I will be checking the tongue weight with a scale we have at work this coming Friday.
The trailer has a max weight of 4,000 lbs and hitch supports up to 750 lbs and I‘m no where near that. I’m probably sitting about 400 lbs tongue or maybe slightly more.
When I went to Saskatoon I had a full tank of water plus all my gear, made sure to put stuff towards the back of the trailer as well. That was with my 2023 and it pulled it good. Was fighting wind the entire way so did 90 kmh and never once did I feel like I was going to lose control or anything like that.
I pulled the trailer 175 km on Friday and it didn’t miss a beat… 100 km/h, varying it on occasion. Found that my speedometer says 102 when I’m only doing 100 according to google maps.
The picture attached showed how I drove basically 1200 kms round trip.
In the bed of the truck I have the spare tire for the trailer, 2x 20lb propane tanks, bbq, griddle, folding table,a little bit of firewood.
I understand where people are coming from, but it always seems to be 50/50 with the WDH.
I Thank everyone for all the helpful tips and comments!
The 2nd shows with the 2nd ball hitch I installed and used.
Ford Ranger 1st trailer hookup, how’s it look? att.jjssMooJV3p6uvQ4gsteNRQTDv6XlITTEUdfo66Y3OY
Ford Ranger 1st trailer hookup, how’s it look? att.St8FuDgZ8kooyT9CtB3v08A8FQa8owcLCY5xPqk837g
dljs1941
2026 Ranger Lariat
Not that you said it, but a WDH doesn't change the fact that the tongue weight is included in the payload.
Also, so many are suggesting a WDH, and all else being equal it is usually a good idea. BUT that's a small camper and the frame may not allow it. The trailer manufacturer should provide guidance.
Don't disagree with your comments. However having owned 4 travel trailers at various sizes the decision regarding a WDH is based on a lot of variables. I've not found trailer manufacturers to be helpful with these types of decisions. Maybe yours if different. Just saying!
Cabose-1
Eli
South Texas
2024 xlt 4x2, advance tow elocker
Student
I tow cars and the kabota using this hitch
GEN-Y GLYDER
game changer if you do not use a wdh. It is adjustable as well. I will never go back to a non torsion hitch. The ride is so much smoother and the bouncing and jarring back and forth are just about gone. Its worth the money. When we get the f250, GEN-Y makes a torsion hitch made for wdh as well, definitely gonna get one sized for a tt we will be towing. The boss is made for different weights as well.
Was going to get a rear sway bar link added to the ranger too, but instead went with the RAS road active suspension. Cornering, squat, and sway are greatly improved with this system. Makes a huge difference while towing. And towing i do a lot of.
Ford Ranger 1st trailer hookup, how’s it look? geny the glyder torsion flex hitches 00
Ford Ranger 1st trailer hookup, how’s it look? WD-BOSS-Photo
johnvosh
johnvosh
Johnathan
Stony Plain, AB
Got the fuel economy numbers for the 1st tow. Going there you go up in elevation from 2,326 FT to 3,020 FT and going back home you go down. Never went over 100 KM/H when towing the trailer on the highway.
1st fill up I averaged 11.7 US MPG (20.2 L/100KM; 5.0 KM/L) and drove 218 KM's
2nd fill up I averaged 14.2 US MPG (16.6 L/100KM; 6.0 KM/L) and drove 133 KM's.
Thanks to everyone has replied to this post, I will be taking everything into consideration moving forward.
2427
jeff
canada
24 ranger xlt
Parts
How’s it look? I think I’ll either need to get air bags or upgrade the shocks. It is sitting a bit different with the same setup as the previous Ranger with fx4 pkg. I’d rather not get a WDH if I can help it. It pulled good the short distance to work!
Get the WD hitch ,you won't regret it.They haul so much better and it will take all the bounce out of it which will ruin your front tires.
johnvosh
johnvosh
Johnathan
Stony Plain, AB
For everyone recommending the WDH, I have found two that I am assuming would meet what I would need.... The trailer has a GVWR of 4,000 pounds and I have no plans to get a bigger trailer or tow anything bigger with this truck. The Curt brand I would also get the sway control thing as well.
One of my coworkers recently saw a trailer accident happen in front of him and he showed me pictures. So after that and reading your responses have decided to look more into getting one. I am in Canada and don't want to spend a fortune to get one, so found these two....
Curt Brand or Husky Brand
Satex
Blake
San Antonio
2024 Ranger 2.7 Ecoboost
Make sure your RV manufacturer doesn't recommend against a WDH. They're probably neutral, but the manufacturer of my RV recommends AGAINST WDHs for my specific model. In my case, it's a function of frame construction.
Dave8311
2025 Ford Ranger XLT
All of you guys recommending a WDH for this lightweight trailer, do you us a WDH when towing a 3,000 - 4,000lb boat? I've never seen someone tow a boat with one. So, why is it recommended for this trailer?
The strength of the frame is the main reason boats don't use WD hitches, especially on aluminum framed trailers.
For the OP's trailer a lightweight WD hitch with sway control would be helpful, with the emphasis on sway control. Which is why I recommended the Andersen WD hitch. I would not use a heavy steel bar style WD hitch like an Equalizer with that setup
johnvosh
johnvosh
Johnathan
Stony Plain, AB
I brought the trailer to work this morning as I'm heading out after work and filled the water tank full. I then went onto the most level part of our gravel yard and disconnected the trailer.
Measuring from the ground to the top of the fender the front measured at 35.5 inches and the rear measured at 37.5 inches. After I connect the trailer it measured 36.5 inches both front and rear.
I also took and weighed the tongue of my trailer with a full tank of water, full 20lb propane, group 31 battery. I have some stuff in the front storage, but not a lot, the bed is at the front....
The tongue weighed 283.4KG or 624 pounds. If I took and emptied the water tank then it would take the tongue down to about 375 pounds.
Dave8311
I would weigh the truck at a 3 pad scale, like a CAT scale, with and without the trailer and see if any of the weight is coming off the front axle.
If it does that would no be acceptable to me.
A always, your mileage may vary.
NM Mike
Whenever possible, I wait to fill my fresh water tank until my last stop before setting up the camper. I realize this isn’t always possible. But water in the tank adds a lot of weight, why tow that weight around if you can avoid it.
johnvosh
johnvosh
Johnathan
Stony Plain, AB
I would, but the closest one is about 60km from me. There is a single pad truck scale about 10km from my storage lot that could possibly use, I have thought of it, just haven’t been able to actually go and weigh it yet. That’s why I did the true tongue weight today so I at least knew that!
I have been trying to do that, but they don’t have water at the campground I’m at, it’s only 30 min drive from work. The funny thing is, it pulled it no issues, just wish manufacturers didn’t lie with the weights.
Next year I’m adding a rear bumper since it didn’t come with one, mounting the spare tire back there and a small utility box back there to move water hoses, power cord, etc… try and adjust some of the weight on the front.
SLJ
The Finger Lakes
If you have the trailer set up properly you shouldn't need a weight Distribution hitch. It's the thing now to just cover a problem with the set up by adding a WDH. If you have too much squat, a camper that small is loaded wrong. Fix that first. Check with the camper manufacturer as a WDH can actually snap a tongue right off the camper frame by putting too much pressure on it when towing over steep angles like parking lot entrances.
