2.3L and 2.7L Engines
Mock01
AZ
2022 Ranger
I looked at the Bronco forums and it looks like the BRaptor uses the 10r60. I assume the RRaptor wouldn’t be any different, especially given that it’s the same engine but slightly detuned.
Per MotorTrend regarding the BRaptor:
“Upstream of all this, the transfer case gets a stronger clutch for 4A automatic on-demand engagement, but it carries over the 3.06:1 low-range ratio and overall 67.8:1 crawl ratio. The standard 10-speed automatic is unchanged but for a revised torque converter and the addition of a second transmission oil cooler.”
I’d think the RRaptor would receive the same treatment…would a revised TC and additional cooler bump up the max torque rating about the standard 443 ft-lb?
Scooter
Scooter
Vancouver, BC, Canada
65 Comet, 2011 Ford Ranger
--Machinist
I see it does have the 10r60. One of the reasons Ford went with this transmission is it has less reciprocating weight thus better fuel economy. Old Ranger has 10r80 and ROW diesels have the 10r80 on new Ranger. interesting the ROW 3.0L diesel makes the exact amount of torque 443 ft-lbs
CaptainTed
Ted
Chelsea, MI
21' Ranger Tremor - Lariat
Boat stuff
The 2.3 is enough for anyone using the truck for it's intended purpose... that being said I'm taking my talents to the 2.7. I want more power without a tune because... I just do. I'll also be running larger tires than stock. It should sound better, and I think the 2.7 has both direct and port injection which is a huge benefit imo.
I agree that Port and Direct injection is an upgrade, but I don't think the 2.3 really has any issue with direct injection only. I've checked the valves on my 21' ranger twice now and there was little to no accumulation at 50k.
LuckyMonkey7
TX
2002 Lightning
adding a throttle body port injection system would solve the issues on a 2.3 for not much money
many companies create aux fuel systems that accomplish that for the 2.3 platform
goalieThreeOne
Memphis
2022 F-150 Raptor
A catch can would be cheaper
Scooter
Scooter
--Machinist
Just curious how you would check the valves for carbon. You would still have to take off many items to even view the area with a camera. Was a shop doing this. Is this recommended from Ford to check this. Carbon should not be a problem if you are putting the motor through a correct heat cycles.
goalieThreeOne
Memphis
2022 F-150 Raptor
but may not solve it entirely
stuff gets by catch cans and unless it drains back into the crankcase, you have to empty it
Depends on the catch can and how you install it. Some cheaper catch cans only trap oil blow by during idle. If it’s plumbed correctly, there will be constant vacuum and should catch most of the blow by during all stages. Even if it’s not perfect, it’s more than enough to delay whatever power losses you’re likely to get from buildup many tens of thousands of miles longer.
That’s my take anyway.
CaptainTed
Ted
Chelsea, MI
Boat stuff
I removed a sensor on the intake plenum and was able to get pictures of a valve with my borescope. Ford doesn't have any sort of recommendations regarding the intake valves. You can look at my thread here:
https://www.ranger5g.com/forum/threads/carbon-buildup-at-25k-miles-a-short-story.21462/
I really don't think there's any point in catch cans either.
Scooter
Scooter
--Machinist
I found this interesting trying to find info on the 10r60 and 10r80.
60 means 600 netwon meters, 443 ft-lbs torque rating.
80 means 800 newton meters, 590 ft-lbs torque rating.
Some 2020 Explorer/Aviator vehicles built on or before 19-May-2020 and equipped with a 10R60 automatic transmission may exhibit a harsh 7-6 gear downshift. This may be caused by the A clutch piston return spring snap ring becoming dislodged. this has been resolved.
Mike in UT
Utah
2024 Ranger XLT Super Crew FX4, 2.7, Adv Tow/Tech pkg
IT technician, retired soldier (11B, 19D)
Any word on when we'll be able to order a Ranger with the 2.7? My local dealership insists that the 2.7 will only be available on the Raptor (!) and that they're not getting any Raptors on allocation.
goalieThreeOne
Memphis
2022 F-150 Raptor
You need a different dealer because every part of what he told you is wrong. Every dealer is getting one Raptor allocation. But that doesn’t have anything to do with the 2.7L because the Raptor comes with a 3.0L. The 2.7L is not yet available for order and no one can tell you for sure when it will be available.
Mike in UT
Utah
Oh, I'm sure the owner is keeping the Raptor for himself if they're getting one. But WHY would they think that the 2.7 is only going to Raptor? This crew is more honest if somewhat less informed than the last crew that owned this dealership, and I'll take ignorant honesty over knowlegeable dishonesty any day of the week and twice on Sundays, but it's still irritating.
goalieThreeOne
Memphis
2022 F-150 Raptor
I don’t buy things from people that don’t know about them. What’s the point if they can’t answer my questions correctly. An ignorant plumber might be honest, but honest doesn’t fix my pipes.
