2.3L and 2.7L Engines
Zackattack2846
Utah
2018 gmc canyon
Tech
Anyone have info on the reliability of the 3.0 v6?
My fear is that they arnt in high volume (I know bronco raptors are few and far between)
Have they worked out all the problems on them? I got a gmc 2018 3.6 v6 and while performance numbers don’t wow me, it’s pretty bullet proof with all the off-roading iv done with it
goalieThreeOne
Memphis
2022 F-150 Raptor
Tough question but also not so tough question.
The Explorer ST has had this engine with a different tune since the 2020 model year. I frequent the Explorer forums and haven't seen anything major come up as far as the engine (most complaints are about the camera, software, and rear subframe bolts). The engine has also been in the BRaptor for two model years now, and although I don't follow them closely, I haven't heard of anything major. The ROW has has this engine in the RRaptor for a year at least and I haven't seen anything there yet. So the answer is...no major issues thus far. But no one can predict how these things will age.
Coming from a 3.5L EcoBoost, here are my best tips:
1. Change the oil more often than the manual and the car tell you to. You should be aiming for less than 5K intervals. This is the cheapest insurance against a variety of problems caused by oil starvation and sludge buildup.
2. The 3.0 is DI only, so that means over time you will get buildup on your intake valves which will rob you of power over time. A true two mode catch can (not a single mode Amazon el cheapo) will help to catch contaminants before they settle on the intake valves. Ford has no official process for cleaning buildup off the intake valves so the only move is to prevent it in the first place.
3. We are fortunate that the 3.0L has an external water pump. The 3.5L water pump issues are legendary. So if it goes, it at least won't grenade your engine. That being said, flush your coolant system and keep clean fluid in it at all times to prevent corrosion and contamination.
4. Don't overlook your air filter. A dirty air filter is a good way to choke out your turbo and rob you of power.
Hopefully someone in this forum will do the leg work of doing some oil analysis to share with the group so we can keep track of how well this engine does with oil change intervals.
Scooter
Scooter
Vancouver, BC, Canada
65 Comet, 2011 Ford Ranger
--Machinist
Scooter
Scooter
--Machinist
I see both the Ranger and Raptor has Terrain Management System,™ Trail Control™, Drive Modes, Off-road screen with front camera. Trail Control, which is like cruise control for off-roading. The driver simply selects a set speed, and the vehicle manages acceleration and braking. Are both the systems the same on both vehicles with the Raptor having a couple more modes and a crawl ratio. Is the 4A Maximum crawl ratio 67.88:1 in the transfer case or is this done electronically. Is this correct: So the standard Ranger can be put into full time 4 wheel Drive and the clutches in the transfer case will make up for different wheel speeds. Confused about the rear locker then. I guess the Raptor will do both full and part time 4 wheel drive, part time, where the wheels will turn at the same speed. . What makes the Raptor 4A different or is that part time 4 wheel drive. Just trying to understand these systems.
goalieThreeOne
Memphis
2022 F-150 Raptor
How does the Crawl mode differ from the Ranger to the Ranger Raptor. Does it work the same I see the Raptor has a crawl ratio in the transfer case where the Ranger does not. Is the Crawl mode still used on the Ranger.
All vehicles have a crawl ratio. It’s the ratio of torque at the wheels compared to the torque at the flywheel of the engine. It’s not related to a crawl mode.
Deleted member 6764
From some of the documents (towing guide and body builders) it looks like they may only offer the 2.7L V6 ecoboost with 4x4. Does anyone know if they will offer it with 4x2?
richman555
Rich
Collegeville, PA
2025 Ford Ranger 2.7 XLT FX4
Software Engineer
For the past couple weeks I’ve been debating between the 2.3 and 2.7. Initially I was hoping for the 2.7 to be available in the new Ranger and was 100% set on that. However, the price of the Ranger is more than I was guesstimating and I’d really prefer not to wait a year to get back in a truck for several reasons. That has me considering the 2.3.
I test drove a 2021 or 2022 Tremor the other day, and it had enough pick up and go on the flat roads of Florida, although I’m not sure if the Tremor is tuned differently than a regular Ranger. But my main concern is longevity since I plan to keep the truck for more than a decade. Ford changing the 2.3 in the Mustang to be dual injection basically confirms solely being direct injection isn’t a good thing.
Decisions, decisions…
Just remember that that the Ranger has been using the same 2.3 liter for years now and folks generally seem to be ok with it. I would also like some extra MPGs if it is possible.
Wayfaring Ranger
STL
Agree with this and that's why i'm not waiting on the 2.7
If i wanted a faster vehicle, I wouldn't be buying a truck and I'd keep my FoST or upgrade to a mustang/camaro/ctr/its. The 2.7 doesn't change the towing capacity or the payload, it doesn't make offroading any better, it will get worse MPGs and it will cost at least a grand more.
HighDesertRanger
Oklahoma
Ford Fusion 2.7
Sales Manager
On the Bronco the 2.7 engine is an $1,895 option. I expect it to be similar with the Ranger once it’s available.
Gator21
FL
F150 & Wrangler
I've read reports of brake failure with the 2.3 and a NHTSA investigation, so I don't know if I'm overthinking or not but it worries me. Furthermore if they made a point to change the engine to be both direct and port injection going forward in the Mustang at least, that says they recognize a problem and are trying to fix it for future iterations. They're not spending money to re-engineer an engine just for fun.
Will the 2.3 really have extra MPG? In the Bronco it's 20/21/20 combined for the 2.3 and 19/21/20 combined for the 2.7. According to some owners on their forums, if you push the 2.3 at high rate of speed and/or elevation, then the 2.7 gets better mileage. So it seems like a wash overall.
I would love to save money and be able to order early before they start taking options away by going with the 2.3. I'm just worried about longevity with the direct injection only and the brake system that comes with the 2.3. Furthermore, I don't think MPG will actually be an improvement.
Gator21
FL
F150 & Wrangler
This would be a game changer for me since I recently decided to go 2wd instead of 4wd. This is the first I've ever heard someone mention that possibility. Why wouldn't they offer it with 2wd? Doesn't make any sense.
Deleted member 6764
Same here, I've ordered a 4x2 XLT with the 2.3L and I'm interested in the 2.7L, I would possibly modify the order. but the preliminary towing guide makes it seem like it may only be available on 4x4, but is just preliminary. The first body builders guide also only said 4x4 for it, but on the newer one it was removed altogether.
Deleted member 6764
https://www.ford.com/cmslibs/conten.../towing/pdf/2024-Ford-Ranger-Towing-Guide.pdf
However CR says the 2.7L V6 will be available with both. Two dealers I've asked have no clue. So, hard to tell at this point.
richman555
Rich
Collegeville, PA
Software Engineer
Interesting, and if I Google this information, I get sent down a rabbit hole. Hopefully this is something which gets addressed and Ford knows about. Really sounds scary!
