2.5" or 3" level kit recommendations?
Ranger75
Tennessee
2024 Ranger
What level kit is everyone using? Are you doing 2.5" or 3"? I've seen many different articles on this but just looking for which actually gives the better look. Does the 2.5 still have a little rake to it, and if using a 3" did you guys use longer sway bar links?
Sauce
Northeast
2025 Ranger XLT FX4
I did a 2.5" superlift, which included the sway bar links (most other kits don't). I'll measure when I get around to it, but to my eye it looks dead level on a 2024 XLT FX4 and no issues with the ride at all. I wouldn't want to go any higher based on look and additional stress on the suspension. 2-2.5" looks right to me. Kind of a stopgap for additional tire and ground clearance while waiting on a proper suspension lift to be released...
White willy
Earth
2025 Ranger
I did ForRanger lifts level on mine and a BDS rear shackle.
Afsigma21
OH
2024 FX4 Lariat v6
Air Force
I did the rough country 2.5 on the front and a truxxx 1 inch on the rear and it has a SLIGHT rake.
Level when a trailer is hooked up, as intended. the extra clearance really changes the look in a positive way!
pasali
Paul
Livermore CA
Carpenter
fordrangerlifts.com 3” front 1” rear. No other mods.
Ford Ranger 2.5" or 3" level kit recommendations? IMG_0159
Ford Ranger 2.5" or 3" level kit recommendations? IMG_0160
Ford Ranger 2.5" or 3" level kit recommendations? IMG_0157
do the raptor spacers and the regular ranger spacers have hte same bolt spacing so they can be used interchangeably on the models?
its way easier to find raptor spacers in different sizes than regular ranger spacers
Ranger75
Tennessee
2024 Ranger
Only thing I find on super lift with links says it's only a 2" lift. It states a 2.5" spacer, but details say it only raises 2"
pasali
Paul
Livermore CA
Carpenter
No, 315/70R17 BFG KO2’s on Method 708’s (34.4” tall)
Reactions: GLW
so no one has any ideas on the spacer bolt pattern?
White willy
Earth
2025 Ranger
I'm assuming you did the 3" lift?
Yes sir,I did.
The alignment shop I use had no problems realigning it.
Now waiting on the wheels I want to not be on back order….
They will be 17x9. O offset with a 285/70-17 Grabber X3
Ranger75
Tennessee
2024 Ranger
Yes sir,I did.
Did it sit level before the rear shackles or did you have to use them to level it?
