2.7 oil dipstick with “H” stamp
rlcampbell64
Randall
Cross Plains, TX
2024 Ranger Lariat Sport 4x4
Can anyone confirm the dipstick with the Triangle stamp exists? Or are they all stamped with the H designation?
I’m referring to a 2024 Ranger Lariat with the 2.7 EB engine. The EPN on mine is FT4E-6750-BG. My understanding is that the new triangle stamp is the newer version. If anyone can confirm this I would appreciate it. Thanks to all replies and thanks to the forum.
LeeHo
Lee
Niles, Mi.
Where is the stamp located and what difference does it make?
rlcampbell64
Randall
Cross Plains, TX
The stamp is in black ink at the very top of the loop (handle). Mine is the “H” stamp, which I suspect is an earlier version of the stick that has since been updated with a black triangle stamp. This would be my second 2.7 engine owned. My 2016 F150 had neither. The reason for my inquiry is the stick consistently measuring overfilled on my 2024 Ranger Lariat with the 2.7. I have measured 6 quarts out, and 6 quarts in, yet it still shows to be over filled by a quart. Based on the endless threads on the Bronco forums about wrong dipstick dilemmas, I’m trying to determine if the “H” stick may simply be the issue. It’s my understanding that the newer dipstick with the triangle stamp may be updated, but still shares the same part number. I’ll try to update this thread with a picture of the stamp.
Thanks.
1996-to-2025
Troy
My 2025 XLT 2.7 built in March has the H dipstick.
rlcampbell64
Randall
Cross Plains, TX
That’s 6 quarts out, 6 quarts in. Sitting overnight in the photo. I have also checked after normal operating temperature achieved, waited 15 minutes, checked and makes no difference. I have checked 15 minutes (per Manual) , 10 minutes, 30 minutes, 60 minutes, overnight. Doesn’t matter, always shows overfilled on that stick.
I absolutely did a COMPLETE drain, measured 6 out, put 6 in. That’s why I’m asking about the sticks. I asked the dealer about this, and the response was “ anywhere on the stick is fine “
Anyone have any experience similar to this? I don’t recall any issues like this in my 2016 F150 with the 2.7, but I also don’t know which stick Ford used back then. I am 61, and have been changing oil in vehicles for over 40 years. All replies are appreciated.
Holy cow, thats a lot kver the factory marks.
Can you just etch your own marks, for now? Since you are foing ro try and replace it anyways, it wont hurt anything.
I had to hit the junkyard for a trans dipstick for a wrangler we had gotten super cheap. Mopar doesnt make, and bo one makes, a trans dipstick for the wrangler trans in the early tjs. I ended up just getting a grand cherokee stick and cutting it down, then marking it myself. I filled notches into the side at the high and low marks but thought about etching them instead
rlcampbell64
Randall
Cross Plains, TX
I may have to, I can’t confirm the stick with the triangle even exists, or that is any different. I did see a fellow on the F150 forum that did exactly what you described and cut a notch on the stick.
I ordered a stick from Ford , but it’s the same one I have with the H stamp.
That’s why I made this post, to see if anybody has any experience with this.
Thanks for your reply! I appreciate it.
1996-to-2025
Troy
First time checking the oil. Only 611 miles on the odometer. Mine appears to be 3/16 to 1/4 inch over the full mark.
Ford Ranger 2.7 oil dipstick with “H” stamp dipstick
rlcampbell64
Randall
Cross Plains, TX
Thanks for looking at it, it’s an odd and frustrating thing . My Ranger has 4200 on it . Been this way since I took it off the lot. I am very suspect of the dipstick.
I appreciate your reply
rlcampbell64
Randall
Cross Plains, TX
Anyone else have this issue, or can chime in?
Thanks for any assistance and thanks for the great forum.
BriSco
'24 Ranger XLT, 2.7L V6
I just came across the thread. I went out and looked at mine. It has an H and it is at the full mark with about 4500 miles on this oil change. I just pour 6 quarts in and don't check it.
rlcampbell64
Randall
Cross Plains, TX
Thank you sir
