2025 Lariat Auto button LEDs on climate control- Ford Tech reply?
Rangerjimm
2025 Ranger Lariat 2.3
The first press on this knob turns the auto temperature on or off. According to the manual repeated presses "Adjusts auto mode". There are three leds on the knob that cycle with the repeated presses. The manual offers no additional info on what this adjusts. It does nothing to the blower. Can someone from Ford shed some light on this mystery?
WWilli
Wayne
New Bern NC
2025 Ranger Lariat FX4 2.7
IT Analyst
Thats a good question... What does that even mean ??? I saw that myself in the manual
Raptortugal
Portugal
Ranger Raptor 6g
Same thing on the Raptor.
What is this 3 position AUTO mode ?
At Audi for example, the AUTO mode will blow hard at the beginning to reach the requested temperature and then stabilize AUTOMATICALLY.
What is the 3-position AUTO mode at Ford for ?
It's not really automatic in fact !
Awirez
The Auto button you are referring to is on the screen, for trucks with Automatic Temperature Control. Each level affects the automatic fan speed. There are 3 levels indicated by the colored lines below "AUTO".
Ford Ranger 2025 Lariat Auto button LEDs on climate control- Ford Tech reply? 1751312344645-ph
Ford Ranger 2025 Lariat Auto button LEDs on climate control- Ford Tech reply? 1751312372962-p2
Ford Ranger 2025 Lariat Auto button LEDs on climate control- Ford Tech reply? 1751312362714-sx
Raptortugal
Portugal
Ranger Raptor 6g
That's right, but why 3 speeds if it's supposed to be automatic, the speed is not managed automatically.
snowman3
us
none
info from earlier thread + Bronco. But doesn't seem like ppl notice a change in fan speed. I wonder if software or FordScan ignores the level setting or was disabled? OK folks, can anyone notice a change in fan noise?
https://www.ranger6g.com/forum/threads/what-does-this-do.9574/
The 1-2-3 is a fan bias setting (for higher to lower fan speed bias).
Ford Ranger 2025 Lariat Auto button LEDs on climate control- Ford Tech reply? screenshot-2024-04-12-at-21-15-11-jpg
Rangerjimm
Rangerjimm
Rangerjimm
Thanks Snowman3. I didnt see that post cause I dont follow the Raptor sections. Its weird because I hear no difference in the fan speed. Maybe its a placebo from Ford to make us think it is doing something!
Awirez
I certainly hear a difference in the fan speed based on the "AUTO" button settings.
Perhaps try to lower the temperature setpoint to like 61 degrees (since it's summer and the algorithm would call for increased fan speed demand) and ensure you have dual zone enabled. Then test to see if you have any difference in fan speed based on the AUTO setting.
gtyates
Greg
Goodlettsville
2019 Ranger Lariat 4x4, 2021 Explorer Limited 4x4
Manager
This is a great feature actually. On my '19 Ranger the auto setting always had the fan blowing at about the half-way point, so once the truck cabin cooled it would honestly be too much, but if I manually adjusted the fan downwards then it would take the system out of auto mode totally. By having the 3 settings I can control the fan speed better while letting the auto function keep the temperature correct. My '24 Ranger interior is so much more comfortable. Our '21 Explorer Limited was the first vehicle we had with the 3 settings.
EzequielArgentina
Ezequiel
Buenos Aires, Argentina
Ford Ranger T9 2024
Auditor
Based on what I read in the past for other car that I had.. the 3 "auto" levels are associated to the speed the desired temperature is reached.
Let's say you set the temp to 39 and fan in 1, it will take a couple of mins to reach that temp
if you set the fan in 3, the fan and AC system temp will increase to reach out to the desired temp faster.
Mean Dean
Atlanta
2024 Ford Ranger XLT 4x4
I for sure hear the difference in fan speed when I change the setting in my XLT.
