25BlackRaptor
- First Name
- Chris
- Joined
- Oct 21, 2025
- Threads
- 9
- Messages
- 96
- Reaction score
- 129
- Location
- Charlotte, NC
- Vehicle(s)
- 25 RR
- Thread starter
- #1
Bought the Turbosmart IC from Pandaworks for 812$ OTD. Wanted to get a bigger IC as the Cobb Stage 2 Canned Tune requires an aftermarket IC. Part came in under 3 weeks and was well packaged. No directions included
Check out this YouTube Video for visual directions -
Onto the Install. You can do this in your driveway, no jack or lift required.
1. Drop the 2 x 15mm bolts on the front of the skid plate. Loosen the rear 2, slide the skiddy out towards you and put to the side.
2. Take out the 2 x 10mm bolts holding the IC to tow hooks.
3. Loosen the 4 x 15mm bolts on both tow hooks.
4. Use needle noses and remove the 2 hoses from the passenger side, dropping the metal clips
5. Do the driver.
6. Remove the 15mm bolts on the tow hooks and out comes the IC.
7. Put the bump stops from stock to the turbosmart. Reinstall.
Happy with the fit and finish of the product. Cheers!
Check out this YouTube Video for visual directions -Onto the Install. You can do this in your driveway, no jack or lift required.
5. Do the driver.
