3rd brake light chase lights
paulhut
Paul
Sanger, Texas
I got a reply from MPower on 8/14/2025 that said:
I am not sure when these are going to be released by I can have our sales rep Todd reach out once they are.
I have included him on this message.
Locust13CT
Tom
CT
Aircraft Inspector
These Mpower lights are what they use on the trucks at the raptor assault school. They told use they were testing them for Mpower and they would be available eventually for the Ranger, and that was back in July when I was at the school.
These are the lights I'd like to get when they do release. I'll reach out to them and see if I can get any sort of new estimate.
paulhut
Paul
Sanger, Texas
I still don't see a Ranger version of the MPower chase lights. Has anyone heard anything?
c72k
California
Also looking for a set. I know the prior gen fits from one of the other companies but it’s a 3rd brake light replacement
Oreo_Five8
California
2024 Ford Ranger Raptor (Azure Grey)
Oreo_Five8
California
I haven't hooked up the wiring yet. This was intended to be a test fit and one of the plastic screw clips on the ranger decided to break and start spinning, at which point I said F it and pushed the wire through and routed it into the cabin.
This is how it fits. Flush in the back and gaskets make contact with the cab. However the top parts on both sides slightly sit above the cab.
Wind noise problems? I have STEK over the entirety of my truck, else I'd have tried melting the plastic down / softening with a heat gun on the sides. Alternative is strong double sided mounting tape on just the sides and press down the plastic onto the truck.
While I don't think it will leak, I'm also thinking about sticking some rtv silicone sealant in the forward facing gaps on those side/top areas and then covering it with some clear gorilla waterproofing tape just to be extra safe.
Thoughts? Ideas?
Edit: pictures not going through. I'll update asap
One Pic for now -
I like everything but the top fit, they need to fix that for the Rangers.
RRaptorscallion0331
Colin
I opted for rad designs,
https://raddesignsoffroad.com/products/2019-ranger-billet-3rd-brake-light
ordered 05/21, have not gotten a shipping confirmation email yet. Website doesn’t say it (maybe I missed it) but in an email from them they state that all orders have a 5-10 day lead time. I also optioned the Baja designs s2pros for the outer lights. In the meantime for TRR I put two aux beams on aluminum flat plate and bolted them behind the back seat.
Jabberwocky
Austin, TX
'24 Raptor Ranger, '17 BMW 328d Sport Tour
This is my first off-road vehicle so I too am looking into a 3rd brake chase light, after my first TRR I realize it was pretty much required lol
I plan on pairing them with a pair of lower rear bumper mount lights, from SPV (Baja Designs). Typically do these lights run with the amber/yellow bulbs as well?
EDIT: I am going to pull the trigger on this mount from Bullet Proof Diesel comes with Baja Design lights already attached.
There's also a double antenna mount option if needed. This was recommended by Peter from FMI. Will update once it's installed.
RRaptorscallion0331
Colin
I installed mine pretty much the weekend after TRR @Jabberwocky a little tricky running the lights and antenna coax but turned out pretty good!
Ford Ranger 3rd brake light chase lights IMG_0266
Ford Ranger 3rd brake light chase lights IMG_0268
Ford Ranger 3rd brake light chase lights IMG_0265
