Aftermarket rear diff cover Non raptor
Hootbro
Delaware
2024 Ranger STX 4X4
Yes, it came with a gasket, the same type of flat gasket the Ford Performance cover uses.
The OEM gasket is reusable if not messed up. I purchased and used a new OEM just in case.
Problem with using the OEM gasket with aftermarket covers and their hardware designed around either a thin flat gasket or RTV, you loose about 5mm of grip length with the attachment fasteners.
May or may not be a factor but will depend on how hard someone wheels their vehicle and smashes on the diff cover.
Awirez
SC
Agreed. I still had ~1.5x thread OD of thread engagement. If not, I'd get 5mm longer fasteners.
RB205
BB
Denver
XJ
I'll have to do a separate write-up on this later but ARB covers fit with a little modification.
I reused the stock gasket but basically replaced all the hardware. Probably not worth the hassle if you're buying new but this was a Marketplace steal from a while back.
Also change your rear diff fluid. I've never seen rear diff fluid as black as mine came out after 10K miles.
Ford Ranger Aftermarket rear diff cover Non raptor PXL_20260607_004006018
That's nice looking, too /\
The wife wants the arb for her wrangler, which has the same rear as my ranger. I may just do the arb also.
2019 wrangler m220
Ford Ranger Aftermarket rear diff cover Non raptor 20260813_143144
2024 ranger m220
Ford Ranger Aftermarket rear diff cover Non raptor 20260813_143129
