Amber DRL Conversion Options
Deleted member 6814
Well that's very good to know, I remember seeing in one listing that it was specifically for US spec headlights but the ones I ordered listed T9 Ranger so now I'm thinking I'd have the same issue as you.
When you say you struggled to get the plate off, do you mean the heat sink from the back of the housing? Did you remove the headlight from the truck first or was this with them installed? I'm asking because maybe it's easier for me to pull a headlight and solder on my own LEDs to that plate on my workbench
Yes, the heat seat sink on the back of the housing. It is not possible to get just a headlight off, you have to take almost the entire front end off to get to the one bolt on the headlight. The bolt is right by the fender flare so you also have to pull the wheel liner off to get to the headlight.
Deleted member 6814
Also that “Jho” brand is the exact same one that I ordered.
JustNick
JustNick
Nick
BatonRouge
Shelter Green Ranger Raptor
SOLA Motorsports
Sounds like a modern car to me, they really enjoy making the headlights impossible to easily remove for some reason. You wouldn't happen to have the original one that you broke still laying around would you?
I got confirmation from the seller that the Jho modules I ordered do NOT fit US spec trucks, so the order got cancelled. I'm considering ordering a rework hot air gun and replacing the LEDs on my factory boards, but I'd hate to take it apart twice since I don't know what size SMDs I need to order
Ag3ntC00p3r
Product Manager
It's too bad it's that difficult to get to the modules. I was debating just throwing some layers of Kapton tape over the white LEDs to see what color/intensity you could get on the cheap.
The previous threads mentioned that Diode Dynamics might make some modules. If they do, I hope they make grille lights too with the same LEDs so they color match exactly.
JustNick
JustNick
Nick
BatonRouge
SOLA Motorsports
Alright, so I went ahead and pulled the lights out of my truck and am trying a few options out for us. Firstly, here is what the boards look like for us. It's significantly different to the overseas options as previously discussed, but looks simpler in terms of circuitry. Its probably possible to change just the LED if you have access to a hot rework setup, but otherwise it's not happening with a regular soldering iron
Ford Ranger Amber DRL Conversion Options 20241229_143314
It's attached using 3 bolts to the back of the housing and a single cable as shown below. The connector seems like it'd be pretty fragile and there's really no way of getting to this without pulling the headlight completely, which is not a small feat. You can also see here the four light pipes used for the DRLs, and they line up with the 6 very small LEDs that shine into them from the board. The heat sink seems to indicate that these are all driven using 12v, but that was not verified.
Ford Ranger Amber DRL Conversion Options 20241229_143337
Using an LED flashlight of similar whiteness to the DRLs, I lit up the light pipes with strips of kapton tape on only the upper section. This was put directly onto the light pipe surface itself. The result was a very yellow DRL that wasn't really what I was hoping for. The tape itself seems very amber on the roll, but once it is actually used it the tape is definitely yellow.
Ford Ranger Amber DRL Conversion Options 20241229_143443
Next we held an amber turn signal bulb over the bottom section of the light pipes. This is significantly closer to the amber lights on the rest of the Raptor family. We left the kapton tape on the upper section to show the difference in hue. The brightness difference is not real, the flashlight was struggling to illuminate both sections at the same time.
Ford Ranger Amber DRL Conversion Options 20241229_163732
The next steps are to find a film that can be placed over the light pipes permanently. I currently have on order an orange/amber film intended for window tinting, which should arrive in a couple of days. We had considered using translucent amber model car paint, but I'm worried that they won't last over time. I'll keep you all posted on the results.
Muffin1
Rob
NJ
WOW, props to you for undertaking what seems to be a bit of a job there taking to take out the assembly.
On your first pic your showing the back of a circuit board (for lack of a better description) there is a name imprinted on it could that be the manufacturer??
Maybe trying to reach out to them about the specs on that piece and any help from them on how to change the color, or do they have a replaceable part to swap, probably a longshot but an option to check into positive or negative answer.
Peter
Milwaukee
Wow this is the most detailed work I’ve seen. Now that I see the light pipe situation it seems really doable. I design custom PCBs and work in lighting. With some proper dimensions and specs I may be able to recreate this PCB with amber LEDs
JustNick
JustNick
Nick
BatonRouge
SOLA Motorsports
It looks like they're made by Koito, which a quick Google search says they're a Japanese company that specializes in lighting and vehicle electronics (makes sense to me). I was wanting to take the board off the heat sink as well but I don't have enough thermal compound in my computer hoard box to re apply it unfortunately. I like where your head is at, I'll have to see if I can find a contact to message over there
JustNick
JustNick
Nick
BatonRouge
SOLA Motorsports
I'll see what I can drum up for you, it almost looks like the circuit is a simple 12v+ and ground to the LEDs and then some sort of analog "hey I'm plugged in" circuit that goes back to the headlight controller. I'll take some more detailed photos of the board in the morning
Muffin1
Rob
NJ
@JustNick Ha Ha always wanted to be a Detective when i was growing up, asking questions trying to figure the how's & why's :LOL:
Peter
Milwaukee
Yeah I recognize most of the circuitry. Based on what I’m seeing though it looks like the voltage may be higher. If I’m reading this right the string voltage is closer to 18V (6 LEDs and ~3V per led) which means they are doing some sort of boosting going on. Looks like there is an NTC for temperature measurements as well as power and ground for the NTC. Overall I would say with some caliper measurements and some multimeter probing I remake this pretty easily
Muffin1
Rob
NJ
Here's a view of the rear of the aftermarket assembly posted above showing the wire connections, curious as to if they are similar to the ones when you took yours out?
Maybe this would be a direct fit??
Ford Ranger Amber DRL Conversion Options Ranger headlight rear vi
JustNick
JustNick
Nick
BatonRouge
SOLA Motorsports
That's probably a negative, there's only one plug from the truck's harness to the back of the headlight for the Raptor. Not sure if it's the same for any of the other models, but I'd imagine there would be some difference with the reflector style
JustNick
JustNick
Nick
BatonRouge
SOLA Motorsports
A little update for everyone: I'm still waiting on 2 more vinyl options to come in, but so far the best looking option is using Tamiya clear orange model car paint. The biggest problem with this is that after it cures it becomes very brittle, and I'm not sure how colorfast it will be when exposed to heat/UV over time.
Ford Ranger Amber DRL Conversion Options 20250104_185850
I did also try stacking a few combinations of a reddish film with kapton tape, but I noticed a significant amount of light loss using this method after I reinstalled the headlights. The photos make them seem much brighter than they actually are
Ford Ranger Amber DRL Conversion Options 20250107_123334
I'm currently waiting for some amber Lamin-x and Oracal films to deliver and will report back once I can try them. I honestly think that changing the LEDs themselves is the proper fix, but in lieu of that being viable at this time I will have to live with the films.
