Another one who needs help with bigger tires
Flashe30
Belgium
'23 Ranger Raptor, BMW e61 M5, BMW e34 M5 3.6, ...
My KO2's are nearing their EOL and I would like to go as big as possible on stock rims without rubbing and without lifting. Spacers are possible.
- Is 295/70R17 the max or rather 305/70R17?
- What's a good offroad tire that does well on wet roads? I really liked General Grabbers in the past but it seems like they don't come in 305.
- Does anything need to be recalibrated after fitting bigger tires?
Thanks!
i don't know the answer to any of that but i know you can go into forscan and adjust the tire diameter setting so your speedo and odometer read properly.
Tri5Ford
SW Minnesota
2026 Ranger
Thanks!
Go on line and find a tire comparison site. The difference at 70mph <1mph, is not worth the effort in my opinion.
Flashe30
Belgium
Oh so that's the only reason to do that? Yeah the dealer can do it with my next oil change then.
Anyone who can recommend an offroad tire in 305/70R17 that'll fit and is decent on wet roads?
NASSTY
ME
I just looked on TireRack real quick.....the issue I have with 305/70/17 is they are all load range E (10 ply) except the KO3's in that size are Load Range F (12 ply).
Load Range E would be good for someone that does rock crawling and serious off roading. When I replaced my tires I was trying to avoid Load Range E because I like a nice cushy ride.
Flashe30
Belgium
I've never looked into load ranges. I don't really get what you're saying. E is good foor serious off roading (so more soft, more flex?) But F gives a more cushy ride?
Aemonn
Load range C is the what most vehicles come with that aren't heavy duty trucks, etc. E and F have more ply (thicker sidewalls). They're a harsher ride but more durable for off roading and can carry more weight.
Since C have thinner sidewalls they are lighter (better MPG) and don't transfer harsh bumps as much.
And E tires weigh a bunch so your gas mileage will go down too
Flashe30
Belgium
Aha ok, so it's C that i want. I'll check my local options
EDIT: It looks like we have a different system in the EU. Left is the number on the tires and right is kgs per tire.
70335
71345
72355
73365
74375
75387
76400
77412
78425
79437
80450
81462
82475
83487
84500
85515
86530
87545
88560
89580
90600
91615
92630
93650
94670
95690
96710
97730
98750
99775
100800
101825
102850
103875
104900
105925
106950
107975
Flashe30
Belgium
Anyone using Yokohama Geolandar X-AT G016 P.O.R in 305/70R17 on stock rims without rubbing?
Hande
Hannu
Estonia
Business Owner
Over here, government agencies use Ranger Raptor Diesel with Toyo M/T 35x12.5-17 on OEM wheels.
Spacers on front, also front inner fenders heated / bent somehow, zero rubbing.
dsmclark
Sam
Dorset
Ford Ranger Raptor
Thanks!
I went 315/70/17 AT3 grabbers, with stock rims and no spacers they don't rub anywhere (I did have 35mm spacers installed but took them off). Also my speedo is now spot on, as it read under stock, so no need to change anything in forscan
Flashe30
Belgium
I don't want to do any trimming or bending, but thanks for your reply.
Are you 100% positive they don't rub anywhere? This post states otherwise:
https://www.ranger6g.com/forum/threads/do-315-70r17-fit-on-factory-wheels.23067/
dsmclark
Sam
Dorset
Ford Ranger Raptor
Yeah no rubbing. They did with the spacers so I removed them. Also Grabbers don't seem to like wheel spacers and it rides alot smoother without. I do have my front mud flaps removed and did trim a little bit inside which I am annoyed with myself about as I didn't have to do that.
In that thread where they are mud tyres it could be they have more sidewall. I'll have to dig out some pictures
dsmclark
Sam
Dorset
Ford Ranger Raptor
Here you go. As you can see the spacer makes it so close that it would touch on an uneven surface. Then I removed the spacers (after trimming 🥲) and it has loads of room
Ford Ranger Another one who needs help with bigger tires IMG_1589
Ford Ranger Another one who needs help with bigger tires IMG_1558
