Any Coilover Top Hat Options For RR?
Narwhal Truck Toppers
Richie
24 Ranger Raptor, 21 X5 M50i
Curious if anyone has seen or heard of any companies offering a top hat for the RR? The reviews seem to be great on the Gen 2 and Gen 3 F150 Raptors for getting a slight lift in the front without impacting pre-load as much as a spring replacement or perch collar.
I can’t find any information about any in the works.
Some examples for the F150 Raptor are below.
Ford Ranger Any Coilover Top Hat Options For RR? IMG_0135
Ford Ranger Any Coilover Top Hat Options For RR? IMG_0134
RaptrJr
FL
I was looking for the same I havent seen anything for our trucks. Kind of a bummer as I would probably go that direction
Richie
I’m curious for some feedback from people who have run them on previous trucks. Seems like the best way to get a slight lift and maintain a factory ride.
nedmo
Gold Sponsor
Ned
Australia
2022 Ranger Raptor
Richie
Interesting feedback from the EXO crew that regularly run Baja and have seen several shock buckets and top hats failing. Mostly due to aftermarket springs.
It seems that for the majority who don't run their trucks to the limits a strut spacer works fine.
RaptrJr
FL
Your literally talking about a strut spacer with extra steps.
We have had the Ranger Raptor with 2.5 Fox Live Valves in Australia since 2022 and I have been making parts for them since then and not a single case of damaged or even worn out upper shock bushes. So this upgrade is completely unnesecary IMO.
https://goatoffroad.com.au/blogs/tech-talk/the-ultimate-guide-to-lifting-your-ranger-raptor
Eh same but different. Your strut spacers aren’t going to make the top hat stronger and blowing apart, which is what the top hats are for a long with providing a lift. Granted this has yet to be a problem with the Ranger Raptor coilovers, but it has been an issue for other past Raptor models.
Havasu RR
Craig
Lake Havasu, AZ.
Entrepreneur
nedmo
Gold Sponsor
Ned
Australia
2022 Ranger Raptor
I have definitely seen the Raptors blowing them out and I would put it down the the additional weight on the F150 vs the Ranger Raptor plus most failures are on 37s.
bonjo2
Avery
virginia
2025 ranger
I sent some emails and hoping something can be made. I really would like to see a 5/8-3/4” top space and similar preload to work with stock springs to allow 34-35 tire to not top out at full compression. Ideally a +40-50 offset 17-18x8 and a 12.5 or 11.5 34-35” tire.
I’m planning 18x8 +50 295/70r18 to get same stock weight and only 1/4” off the factory Baja trucks.
The RPG guys had a 1” lift (both compression and space, not told how much of each, but both) that looked good, but is no longer listed.
The SDI setup for the reg raptor seems best, no spherical bushings, cup, 1.5 lift split between pre-load and spacer
I would do a small top spacer, but I’m not too keen on the narrow factory shock/strut tops rubber spring isolator and no cup—having had issues in past. 7 year half-life most automotive rubber.
I still have 10-20k left on my bfgs, so will wait for aftermarket.
bonjo2
Avery
virginia
2025 ranger
Note: I’m 80/20 on/off road, so 70 series tires more than enough. I don’t trail or rock crawl or climb shit, only fast gravel/sand whoops. I love rallycross and rally raid type runs😜. Track guy at heart—this my tow vehicle.
bonjo2
Avery
virginia
2025 ranger
Wow. Odd I got two replies minutes after posting.
SDI says they’re in final testing for the Ranger Raptor. Other reply—no need to mention.
bonjo2
Avery
virginia
2025 ranger
Yeah, saw that. I really don’t want top spacer bigger than 3/4” , 5/8” would be ideal. A little pre-load would be good too, esp in “normal” mode street driving. But the current sport and Baja modes pretty spot on with current progressive spring. It’s always a trade-off with this stuff, and sports cars. Get it perfect for the Sunday whoops/track-day, pay for it the other 6 days a week.
