alloyz250
You installed a Gen3 or the EZ-Flip? Pretty sure the EZFlip didn't ship until early JuneInstalled mine a couple weeks ago on a 2026. Fits great, smooth install.
Gen3, got it back in early May before the EZ-Lift model was released.You installed a Gen3 or the EZ-Flip? Pretty sure the EZFlip didn't ship until early June
I believe you made the right purchase... the fixed panel in my EZ-Flip is probably twice as long as the Gen 3 to accommodate the torsion spring. When my EZ-Flip is resting against the cab, I lose a good 8" or 9" of bed space, where you probably lose half that much. Had I have known, I would not have purchased the EZ-Flip.Gen3, got it back in early May before the EZ-Lift model was released.
RealTruck BAKFlip MX4 (GEN 3) Hard Folding Tonneau Cover
Part #: 448352
Vehicle: 2026 Ford Ranger Raptor 5'1" Bed
Did the drain tubes get installed and in a way they can gravity drain?Had a BakFlip MX4 installed a few weeks ago by the local authorized distributor/installer and it is leaking from both the right and left front with the slightest rinse when washing. Any suggestions before I call the installer and get his side of the story. I did notice that the foam tape is up at the right front corner - leak path ??
Same here. The Bakflip on my Silverado kept the bed dry. On the Ranger Raptor with the GEN3 Bakflip, I do get some leaking on the sides and corners. Not terrible, but it does get wet. Maybe the rail channels don't flow as much water?This is my third Bakflip. the first two (on a frontier and a Maverick) were pretty much water tight. This one was leaking in the same places as yours. I added a little Loctite sealant in the front corners of cover and it stopped a lot of the leaking. I do not think there is a problem with the installation, just the design of the Ranger's bed allows for more leakage.
Fantastic cover! Glad you are enjoying it.I got the UNDERCOVER ULTRA FLEX (GEN 3) HARD FOLDING TONNEAU COVER
When I purchased my Ranger back in May of this year. It’s awesome!
