Best aerosol paint for RR exhaust tips only?
I covered them with Rejex, but they rusted within a month, I would like to freshen them up with black paint. I do not want to install replacement tips. I would use a high temp ceramic paint (I really like the 500 degree Duplicolor Caliper Paint), but I am not sure that the metal gets hot enough to “cook” it correctly.
https://www.duplicolor.com/en/products/wheel-and-caliper/dupli-color-caliper-aerosol-paint.html
Alternatively, I also like Krylon Fusion all in one paint and primer for general stuff, the Satin Black is gorgeous, but I am pretty sure that it is not nearly durable enough for an exhaust part that will get some gravel strikes….. I would like to be able to touch it up if needed.
Krylon Fusion
My wife’s RDX has factory black chrome tips that look like new after four years, mine looked like crap after just a few months. Comments are welcome, thanks!
prybar
Darrell
Quincy, IN
2019 F350, 2025 Ranger Raptor
I used 3 coats of VHT engine flat black and 3 coats of VHT satin clear, previously recommended with great results. Your option, tape everything off or loosen the 1st clamp and remove from the truck. Just follow the instructions on the can.
Doc
Doc
Live oak fla
2024 STX, 2020 HPP Mustang, 2024 Subaru WRX
I used flat black grill paint (Barbecue/smoker)..
RaptrJr
FL
I did a couple coats of VHF high temp and clear coat. Looked great but then one day of off-roading and they need to be redone they look like they were sand blasted.
FullSend
Ninjaneer
Reactions: Doc
nellynel
Nelson
las Vegas, NV
2025 ranger raptor
aircraft mechanic
Same here!
Ford Ranger Best aerosol paint for RR exhaust tips only? IMG_0216
Ford Ranger Best aerosol paint for RR exhaust tips only? IMG_0217
  • Love
Reactions: Doc
maybe you can take them and get them powder coated?
Reactions: Doc
