Black Lug Nuts?
iamweasel
Down Yonder
Ford & Cadillac
On a related note, any of you getting a Spare Tire lock of some sort? (For when the spare is under the truck to prevent someone from walking away with it.
Having a little trouble finding one.....
UpInTheAir
NA
Patience
Very nice....but the post #39 says the Gorilla lugs don't fit for the Ranger is that true? Tried to do that on their website but could never figure out how to pick a vehicle.
The ones I linked off ebay fit perfectly and have been on my truck for almost a couple thousand miles now. They have the exact same surface area and angle/bulge as the OEM lug nuts.
UpInTheAir
NA
Patience
I have a couple other vehicles with decent ATs and wheels that are tucked under the rear. I have never had any concerns about them walking away, even in a higher theft metro where there are no consequences, since they're a pain to drop down. Our spares are on a steel wheel, too, so even less worthwhile for someone to go through the effort. Guessing you could drill some holes and use a small locking hitch pin or somehow block the channel you stick the crank arm? through to drop the cable/spare.
Deleted member 9086
Yep, it pretty simple actually ; https://accessories.ford.com/spare-tire-lock-ramz1a380a
Took me a second or two to realize where it went. But it replaces the little plastic cover you twist a quarter turn clockwise, on the bumper recess under the tailgate.
Ford Ranger Black Lug Nuts? IMG_1392
bowhun2r
Pittsburgh
RR Marsh Gray 25
SAP Solution Architect
seanmc7pt
Sean
Springfield, OH
24’ Ranger Raptor; 2010 6.2L Gen 1 Raptor, 22’ Bronco Raptor (wife’s)
Dry0atmeal
I concur, black is better...
Ford Ranger Black Lug Nuts? PXL_20241009_193848939
Catalyst
Justin
Bend, OR USA
Network Engineer
Black lugs matter
Ford Ranger Black Lug Nuts? IMG_2359
Catalyst
Justin
Bend, OR USA
Network Engineer
Did you pain the "bead lock" ring?
They are powder coated. Used Prismatic Powders PSB-11336 that is their color match to Ford Oxford White YZ.
When I purchased my RR there was minor rash on the two on the passenger side from either the delivery process or a lot attendant at the dealership brushed a curb.
606Timm
Timm
Green Bay, WI
I love it. I was thinking about doing that but difficult to find someone near me to do it.
macky
Central PA
'24 Ranger Raptor Shelter Green
I did a deep dive into lug nuts for the R-Raptor.
(Short answer) Basically due to the sharing forces and wheel pressure/leverage you absolutely need a stock style for the correct surface area for off-roading/jumping/high speed cornering. Now- if you don’t plan on any of the above driving situations (I.e. your truck will stay on road all the time), then a thinner spline lug nut will be fine. If you have after market wheels you may not have a choice due to the diameter of the holes, but if running stock wheels the splines will secure the wheel to the bolts At about 1/3 reduction in strength.
So I went through this thread and am still confused on what the options are for a black lug nut that matches exactly the OEM strength based on your input here.
People are commenting that they have a solution and it fits fine, works great, etc., but that's not the same thing (per your post) as matching the OEM strength. Is bulge acorn the answer?
NASSTY
ME
I'm still a little confused too. Several people here going with Gorilla lug nuts. But over on the fordraptorforum several people saying Gorillas are junk and to go with McGard lug nuts.
DinoBirdClaws88
DinoBirdClaws88
SJ
Coca Beach FL
Ford Ranger/GTR33/Ducati SF
Pararescue
Yes, you want the ugly style bulge acorn that are the same size/diameter of the stock lug nut (if running the stock wheels). I know there’s way sexier look nuts out there (wow, that’s a crazy statement), but after discussing with some amateur trophy truck gentleman they convinced me that that absolute strongest fit would be that fat boys that seat into the wheel and cover/displace the load at the greatest efficiency.
Gorilla lug nuts as a company were great, but sold to Wheel Pros a few years back and has since suffered from an inferior product line compared to before the sell. They are still well made for everyday use and minimal abuse, but if you’re a serious off-road or I would suggest a better brand. I currently use gorilla lug nuts FYI…
