Broken Tailgate Bolt for Strut
Ranger43931
Tacoma
anyone else had the bolt holding strut to tailgate snap in half? Is this something you think ford covers under warranty? It seems strut is fine, but I’ll need to try to extract bolt and get replacement. Any tips appreciated on exact bolt or removal.
2024 Ranger (raptor), 15k miles.
Ford Ranger Broken Tailgate Bolt for Strut IMG_5054
Ford Ranger Broken Tailgate Bolt for Strut IMG_5056
Ford Ranger Broken Tailgate Bolt for Strut IMG_5055
NM Mike
I don’t know what the part number is on the bolt. You might be able to get the bolt out with a small chisel and hammer. The failure spot left a ridge that you could try to use to work the bolt out with. An easy out might work as well.
wow. thats a fairly new bolt to have break during removal
Ranger43931
Tacoma
I wasn’t removing bolt. It snapped when I opened the tailgate during normal use.
Looks like someone over torqued it. It should be warrantied. But do you want your truck sitting at the dealership waiting to fix a broken bolt?
Ranger43931
Tacoma
I don't but may consider if extraction of the snapped bolt is tougher then expected. I just ordered the bolt myself for $7. In case this happens to anyone else down the road, part is 2024-2025 Ford Ranger Tailgate Lift Support Stud N1WZ-26404A42-A.
EdCay
Edward
Tucson
2024 Ford Ranger XLT Supercrew 4X4
Mine also broke 5000 miles. The dealer replaced it
i guess it gets frozen into the cable and when the tailgate drops down and pulls the cable taught, it snaps that sucker right off?
we should probably all verify that our cables move freely around that bolt so we don't have the same issue
got3fords
James
Central Va.
I would just wait for the next oil change and have the dealer do it then. Unless you do your own oil changes.
Ranger43931
Tacoma
Good insight, didn't think of that. I do see the orange cable sticking out sometimes with tailgate closed so something seems wonky.
next time i lower the tailgate, i will put some grease around that bolt so the cable end doesn't corroded and get stuck
‘it’s not the cable, it’s the gas strut bolt.
And I can’t see how there is any real load on that bolt. The strut ends which are plastic would fail first.
i think it was over torqued during assembly and just barely holding on.
EdCay
Edward
Tucson
I live in Southern Arizona, no freezing here, still broke
