Doors require too much effort to close?
Sonny McGee
Sonny
Leesburg Ga
2024 Ranger Lariat, 2019 F-250, 2017 Mustang GT/CS
Is it just me or do the doors seem to take more effort to close than they should. Me and others who have ridden in my truck have noticed it. Coming from F-150 and Super Duty, both of which close with ease.
gaiello1972
Giuseppe
2024 Ford Ranger XLT FX4
I've started to notice that more, I think its the seals or the vacuum it creates is not escaping through the vents that are usually in the back of the cab. My 06 f250's doors were easy to close.
Cabman1939
Randolph Williams
Rushville, IN
2024 Ford Ranger XLT FX4 Sport
Design Engineer
My driver's door is the most difficult one shut. My diagnosis is the cab is pretty airtight because if I crack a window it closes with ease. I have read on here that some people have removed the Styrofoam sheet from between the cab and bed and that fixed the issue. I haven't tried that yet.
Houcat
Kevin
Houston America
2025 Ranger Lariat
I have that same problem with my doors. Will try the styrofoam removal.
Afsigma21
OH
2024 FX4 Lariat v6
Air Force
Its pretty common issue across all the 6g rangers.
I saw several review videos that discuss it. Edmunds comes to mind where they had like 20 people use it over a years time and many had this as an issue for them.
Waterboy8083
Tampa
No issue with the front doors - but the rears take some effort. The 2019 Ranger had light weight doors - finally got the wife to close the back ones softly instead of slamming them then traded it in for the 2024 Ranger and she has to go back to slamming the rear doors (2 kids in car seats, so constantly opening/closing rear doors).
Noticed the door seal on the bottom rear of the back doors was sticking up bit, looks like it's a bit too small to fit the frame correctly and gets pulled up and interferes with closing it. Push it back down and door closes fine, but it stretches back up every day.
Muffin1
Rob
NJ
Mine does it also, i usually click the door then push it for the final clicking and locking,
it is a pita that it just doesn't close normally .
I will check that seal at the rear doors, thanks for mentioning.
alrashid2
PA
Any updates guys? Same thing happening on my brand new '26. I noticed that if a window is cracked, they close with no effort. Definitely a vacuum issue. Wondering if maybe the seals wear in over time and the doors would become easier to close
fastlane
indiana
26 ranger xlt
My driver door is most problematic with this and it also appears to be the door with most visible misalignment (visually looking at gaps, etc)….so I suspect that alignment has something to do with it.
my other issue with the front doors in general initially is how hollow, or “tin can” they sounded when closing compared to other cars I’ve owned previously. And needing to ”slam” the drivers door made it even worse. I could actually see the drivers door skin wobble when closing it.
what helped tremendously was adding some butyl sound deadening mats to the back of each front door skin. Really helped with the hollow sound and also added a little weight to the door so that it closes easier.
Reddog99
So. Cal.
2024 XLT Ranger FX4 2.7
My 2024 driver's door was clunking when closing until I complained and the dealer re-aligned it. It feels better now.
alrashid2
PA
I was able to confirm its a vacuum / tight seal. When I crack any window, they all shut fine! Maybe itll break in over time
AugPal
Augie
Chicago
Retired IBEW
I remember a thread here that said the dealer can realign the doors so they close properly.
dajo
Indiana
My 2025 is also difficult to get closed the first time. Constantly having to stop and even get out to get light off on dash.
Phoenix5454
Connecticut
2025 Ford Ranger XLT FX4 2.7TT
BMET
eh I just live with it, I may have just gotten used to it as well because I don't really notice difficulty closing the doors anymore or maybe the seals around the doors have broken in a little? - coming from a 2014 F150 Super Cab that needed the heat or A/C on full blast or the cab was basically the same temp as outside I don't mind that this cab is sealed better lol
