MTN_WZRD
Brandon
Senior Software Engineer
I got the 2.3 front done too. I need the rear one to release from Eibach. I have a decked system and will have RTT soon. Did they mention when the 500# rear spring will release?
Ford Ranger Eibach coil spring level kit installed on Ranger Raptor - photos IMG_9302
Peter949
Peter949
Peter
Irvine, CA
My truck was used for R&D for your front level. Not sure if they found a truck to R&D the rear heavy duty ones since then.
MTN_WZRD
Brandon
Thank you for your service to the Ranger Raptor Community.
Fordfknranger
Travis
South Dakota
2025 Ford Ranger Raptor
Any updates? How's the ride... Be honest! Lol
MTN_WZRD
Brandon
Hey. Been wanting to update. I ended up putting the rear coils on too. It started out where the front was really high and I’d call “floaty”. That settled over a couple of weeks which was causing the ride to be a little more bouncy. Some of this was due to the tires needing to break in too as well as I found out that I had a broken front suspension sensor?. This made the biggest difference in correcting the auto rebound rate.
This past weekend I ran Medano Pass into the Great Sand Dunes(in Colorado). I aired down to about 18 and it was like a cloud. Since the trip last weekend I feel like my tires broke in even more and my daily drives have improved tremendously.
I will be updating the “zero” on the suspension over the next couple of days via ForScan. My OBDII cable arrived yesterday. More to come on how that helps or not too.
Here’s current pictures.
Ford Ranger Eibach coil spring level kit installed on Ranger Raptor - photos 7EFC2836-A006-4746-99AF-0B46853D4C38
Ford Ranger Eibach coil spring level kit installed on Ranger Raptor - photos C3A18048-2495-4D24-A0E7-2B88C2E8EDF2
Ford Ranger Eibach coil spring level kit installed on Ranger Raptor - photos 78008D91-6973-43F0-AA10-A04EB3FA0984
Ford Ranger Eibach coil spring level kit installed on Ranger Raptor - photos 56F208CA-1BC7-47B3-B578-1EBA7E091CB9
Ford Ranger Eibach coil spring level kit installed on Ranger Raptor - photos IMG_9409
Fordfknranger
Travis
South Dakota
I did a 2" puck up front. Was going to do the coils but didn't want to redo the whole vehicle. I'm on the fence on putting on Eibach coils, I don't want a stiffer ride. But when I tow our camper I'd like more stability in the rear. But yeah after install and alignment I had some crazy bump steer. Then when I recalibrated all the corners it went away. Rides like stock now. But I'd still like to go coils. How does the rear ride unloaded?
MTN_WZRD
Brandon
It was a little bouncy too but they have broken in. I also have about 250# in my bed constantly. I have a Decked system and I’ll be adding a RTT in the near future. So far I’d recommend the coils. Speed bumps are back to stock normal of soft and no complaints right now.
downbytheriver7
Benjamin
London
Ford Ranger Raptor
I recommend the Eibach set. The Raptor has become stiffer. In fast corners on asphalt, only the tire grip limits the car's capabilities :) :) :)
Looking good - do you have a part number or link for europe purchase?
NobleNik
Nik
Philadelphia, PA
None
None
Got the truck back from Eibach. Rides a little stiffer. Looks good tho.
Here is another pic on flatter ground.
They replace your OEM springs with a taller one still using your Fox suspension. Eibach are built better. There is also more travel now because of the taller springs. It doesn't need a new uca. Designed to work with OEM suspension with no alterations.
FYI: I'm a noob also.
did they tell you the front leveling height?
