FLASHING 3rd brake light
1carguy
Loveland, CO
2024 Ranger, 2025 Lincoln Corsair (PHEV), 1966 Mustang Cnvt-High Country Special
retired -TELCO
Anybody installed a 3rd brake light that flashes? This would be the high mounted brake light at the rear of the cab.
Looking for something that flashes 3-5 times (or 3-5 seconds) then goes solid red.
Thanks
GLW
Missouri
morahn
Wi
2025 Ford Ranger Raptor
Same as GLW (product link above) on 2025 RR.
I purchased without the flashy thing.
Ford Ranger FLASHING 3rd brake light 20250912_135010
I think those flashing ones provide a benefit because they attract more attention. My wife's jeep has it and it set it to flash something like 8 times
tamitchener
upland IN
2024 Ranger Lariat
You can buy just the flashing module from amazon , just make sure you get the one for LED or Incandesent application
Onceaneagle
Walter
2025 Ranger Lariat
US Army Retired
Would like to see an installation video for a 2025 Ranger Lariat or the RR. I just read where you have to pull down on the rear headliner to find the connector and fish the wiring to install one. Commentor said the wiring (not sure which one) was too short to go through the brake light opening. If you installed one, can you describe the process? Also, did you get a tight seal?
GLW
Missouri
I didn’t do a video when I installed mine but it was very easy. The provided instructions were almost worthless. If I recall it did show how to pry the liner down to get to the wire and connector. I did all of that through the opened sliding window. Unplugged the existing light and plugged in the new one with the flasher and everything worked. Good seal, much brighter and looks great.
Again, use the instructions as a guide. I think they may have a video of it being installed on a 23 or maybe it was F150. I can’t remember.
Mine was on a 2024 RR.
1carguy
1carguy
Loveland, CO
retired -TELCO
Brilliant sugestion sir. I wasn't very enthused about pulling down part of of the headliner on my nice, sorta new, pickup anyway.
Now I gotta find a module that will work with the Ranger.
Thanks !!
GLW
Missouri
Thanks !!
I believe you’ll have pry the liner down to plug in the module. It’s not that hard to pull it down a little.
TAFV6FR
2025 Ranger V-6 2021 Explorer Timberline
Thanks
My Ranger came from dealer with that installed and I quickly removed it. Contact me and you can have it for shipping cost.
bigb
Tucson
2025 Ranger 2.7
I recall reading somewhere that in AZ and maybe other states they are legal as long as they don't flash more than 3 times.
edit: well I just looked it up and they are not legal here at all except on emergency vehicles. I do think they should be legal on motorcycles though.
1carguy
1carguy
Loveland, CO
retired -TELCO
Gentlemen
This thread was started to get helpfull and friendly information regarding the third brake light on our Ranger. And I welcome and apprecite your help.
This thread is NOT a debate regarding your own personal feelings regarding that flashing brake light. if you feel the need to have such a debate, then start your own thread.
Thanks to admin for your help:like:
GLW
Missouri
I was looking an this since my brake light assembly has a small crack that i may just ignore..how bright are the LEDs in this compared to stock?
Much brighter and looks like factory should have looked. Pretty expensive but those guys make good stuff however their instructions are not good at all.
I went into the install thinking it was going to be a big ordeal. I think it took me about 20 minutes and everything fit perfectly.
