Fluid film undercoat - experience, tips, recommendations?
EarthwormJim
PA
2026 Ford Ranger XLT
Do any of you have any experience applying fluid film undercoat to the new rangers?
I'd be interested to hear your experience and any tips you have for the application.
purdyd
california
I’ve done it.
get a sprayer with a nozzle hose so you can insert into holes. I got an inexpensive one off amazon.
you can use uv light to see where it is applied but only when it is fresh
i accidentally ordered some spray cans and they are handy for touch ups.
remove the skid plates and lower the spare wheel. I did a pressure wash underneath before applying but I should have removed the spare tire before doing that.
use a face mask and safety glasses when applying
put a cover on the floor.
i think it is definitely worth doing but it will hold dirt
https://www.ranger6g.com/forum/threads/sand-lariat-fx4-and-minor-updates.20085/post-317746
Loudpa
purdyd covered all the bases I believe. I've applied Fluid Film on my Jeep for the past 13 years and had very little rust and that's living in the North East.
Well traded in Jeep for a Ranger and this time had Woolwax applied (getting older) we'll see how that works.
PS FF great on shovels, snowblower, etc.
alrashid2
PA
Sweet, I am planning on doing this this year! From the little research I've done, I have heard that Surface Shield is a bit better than Fluid Film. Apparently it goes on easier, is cheaper, lasts longer (up to 2 years) and doesn't have that strong FF smell. Curious if any of you looked into that one?
Intercontinental_Ranger
Cambridge
2025 Ford Ranger XLT FX4
Crisis Cowboy
I was between surface shield and fluid film but went with the latter.
A lot of the negative reviews for surface shield actually referred to the spray cans they shipped in, not the product itself (lot of product lost to leaking, clogging). So not a problem if you’ve got your own spraying equipment.
Fluid Film spray cans were good, came with a precision straw to get inside the frame. I didn’t notice any smell, and I got plenty of overspray on the exhaust, but I was using Fluid Film Black (useful to see any missed spots).
Remember not to spray near the brakes!
FWIW I’ve used fluid film for years and switched to surface shield that I bought in 5 gallon buckets, primarily because the smell goes away a lot faster than fluid film or wool wax. I bought six of the cans of surface shield by accident, not noticing that they weren’t fluid film until I could t return them. I used them and they didn’t clog once. I’ve been keeping cans on hand now for quick touch ups and small jobs. I suspect that the clogging is a thing of the past; else my luck has been freakishly good with them.
lifeline
Chicago
Been a fluid film fan for years. I’m sure the other products do just as well. One thing to note, you can get fluid film black which as the name indicates is black in color and looks pretty nice when sprayed on a frame. Cover up and wear a mask as the stuff gets on everything and has a strong odor that some find offensive.
tivct
Dearborn, MI
Ranger Raptor, Focus RS, Mach 1, F350
Bases have been covered, but I'll just put in another plug for FF. Did it before the first winter on my Focus RS. After 10 years of bombing through salty snow banks with the drift stick, no rust (apart from driveshafts and muffler which spin off/burn off the film). But at this rate they'll survive another 10 years and are cheap/easy to replace.
RonEee
Ron
Holland Michigan
2025 Ranger XLT
I didn't do the DIY version. I took the truck last November to Krown and let them do it. They put the truck up on a lift and get every nook and cranny, and even spray inside the doors. That way I don't have to worry about places that don't get sprayed and it's not that expensive.
So the truck's been through one Michigan winter and there's not a speck of rust even superficial rust on the bare metal parts underneath. I am going to have it done again in November. Whichever way you choose to go just remember you have to do it every year. It's not just apply once and you're done.
The only drawback is that the oil drips for about a week so you have to cover your garage floor or driveway with tarps to catch all the dripping. At least I know they saturated everything underneath the truck.
kirkster89
Kirk
Saskatchewan
2025 Ranger, 2.3, fx4, Lariat
Might be a stupid question.... but how careful should you be with the over spray using FF? Is it bad on the rubber/plastic components? Should I be wiping everything that isn't metal?
Cambridge
Crisis Cowboy
It’s basically clingy WD-40, which is why you should make sure it doesn’t get on the brakes (unless you want the stopping distance of a small aircraft).
Spraying on the exhaust isn’t harmful, it just makes an awful smell when it burns off.
The reason I like Fluid Film so much is that it’s the most idiot proof option. I can take the vehicle to a car wash, and then touch up areas without any surface prep in 5 mins.
This guy has some good videos on applying or using lanolin undercoatings (aka fluid film, surface shield, wool wax, etc). Edit: not sure why youtube links are being a pain in the ass today, but the channel is called “Repair Geek” and he has lots of lanolin-related videos that are worth watching, including long-term tests or reviews or whatever.
