Ford OEM Trailer Hitch wiring question
BennyP92
Railroad
I don’t see what you're trying to show me. Can I get a close-up? Maybe I got that as well
On mine as well, they put the wiring pins besides the license plate as opposed to underneath the truck.
Ford Ranger Ford OEM Trailer Hitch wiring question truck bumper
Just left of my licence plate is the 4/7 pin connector. Just click on my pic and it should enlarge so you can see it.
Cyrusblack
Cyrusblack
Banned
Banned
Pasco County
Yeah I see it now. I don’t got that. I should have gotten the hitch during the ordering ?
jedadiah
Jed
Kentucky
Interesting. On the 5G, it was obvious where the plug should be. You could see it form the outside and cut on the line. It was open behind with a metal bracket behind the plastic. What does the spot beside your plate look liked from behind?
Ford Ranger Ford OEM Trailer Hitch wiring question 1716425550902-eb
Cyrusblack
Cyrusblack
Banned
Banned
Pasco County
I have the same cutout or what have you on the right side of my plate which you can see in my picture. I’ll poke my head underneath tomorrow and report back with a picture.
Tbelland
Tom
Mendon, MA
2024 Ford Ranger
If it's like the 5G Ranger, the wiring will install inline on your frame rail and be pretty easy to do. It might be too early for anyone to have kits available though. eTrailer says this fits, but I bet it's for the 2019-23 Rangers. It could end up being the same. I installed this on my 5G. It comes with the wrong trailer plug for the bumper, so I had get the right kind myself.
As far as a hitch goes, they say they are actively working on a hitch. The OEM will fit better, but will undoubtedly be more work. Here's the install instruction for the OEM.
It might be a bit before anything aftermarket is available.
I ordered the OEM class IV hitch from Ford and now I'm looking for a wiring harness that connects to a 7 pin connector. I tried the Etrailer version but connections didn't fit. They were great about the return however it looks like the earliest they will have a plug and play version is in October 24. If anyone knows about a different option for 7 pin wiring, please post.
Not sure if this is what you are looking for.
All Products for 2024 Ford Ranger (curtmfg.com)
Tbelland
Tom
Mendon, MA
2024 Ford Ranger
Thank you for the instructions. I ordered the OEM class IV hitch kit and will probably have the dealer install it now that I've looked at this document.
FL
I bought the Curt C82ZV hitch from etrailer and it's an easy install with only 4 bolts.
jedadiah
Jed
Kentucky
Post some pics, so that others can see. I bet it looks good and gets even more attractive when people see how much easer it is to install than the OEM version.
The install looks the same as it was on my 5G. I clamped the tabs off the side of the bumper bar to keep it in place. Torquing the bolts to 196 ft lbs was not fun lying on the ground, but doable :)
FL
You're lucky you got that type of hookup, they put a female 4 pin flat connector up under the bumper and I smash my hand trying to pull the connection from the trailer out. This is going to change very soon!
FL
This was a very easy install even with no help available. The hitch is pretty heavy so I jacked it up in place with my floor jack. As you sad, torquing the 4 bolts (2 on each side) to 196# is not easy! I attached 4 pics
Ford Ranger Ford OEM Trailer Hitch wiring question 20240902_142351
Ford Ranger Ford OEM Trailer Hitch wiring question 20240902_142514
Ford Ranger Ford OEM Trailer Hitch wiring question 20240902_142538
Ford Ranger Ford OEM Trailer Hitch wiring question 20240902_142604
JayC
JayC
2025 ford ranger xlt
Parts manager
That is the # needed for the harness for rear bumper to plug into a pin 7 outlet you put on the rear bumper. 2025 ranger xlt
Ford Ranger Ford OEM Trailer Hitch wiring question Screenshot_20250621_191107_Messages
JayC
JayC
Parts manager
Part # is hard to find because description describes something different. But indeed works. Just installed.
renato23
Renato
Brazil
Ranger Black 2.0
Can you post a picture of it?
I was able to buy the towbar and the 7-pin outlet from a crashed ranger and when installing it I found a connection plug under my car and connected it hoping it would work right off because I have the towing menu in my sync4 screen.
It did not work so I decided to scan a friend's Ranger to see if there was something I could change on Forscan so it would work. I activated everything related to trailer but nothing changed. Then I realized my friend's car had a module called TRM (Trailer Module), and mine didn't.
Ford Ranger Ford OEM Trailer Hitch wiring question IMG_1968
Ford Ranger Ford OEM Trailer Hitch wiring question IMG_1970
