DIYPSCM
- Joined
- Oct 13, 2024
- Threads
- 0
- Messages
- 87
- Reaction score
- 103
- Location
- SF Bay area
- Vehicle(s)
- 2024 Ranger 2.7 Lariat
- Occupation
- Engineer
THIS ^
Hi Sequoia,I was successfully able to activate Trail Turn Assist.
1) go to APIM and activate Trail Turn Assist
2) also in APIM (or in IPMA, not sure right now but it is clear to find): activate "off-road trail turn assist indication
3) ABS as build: go to 760-03-01. The second box is 5627. Replace the 56 with D6.
After writing it will show: D6A7 (that's correct).
Now you have a working and indicating Trail Turn Assist.
Actually, maybe you can take a look at the non-as built ABS module and work out what changing the as-built setting does in there.I was successfully able to activate Trail Turn Assist.
I would first update to version 63 of ForScan that has the latest non Asbuilt info.My 760-03-01 is F27C 764F.
I've updated to V63 now - thanks for that hint.I would first update to version 63 of ForScan that has the latest non Asbuilt info.
@Sequoia , do you have an updated sheet that has the detailed As Built tables? The one I have is missing a couple. Read below to see what I mean.
Go to the "ABS-Raptor" tab on the spreadsheet, then find 760-03-01. From there, you can decode what each parameter does.
Disclaimer - those tabs on the spreadsheet were snagged from F150 forum earlier thsis year and have yet to find a new one. I've found a few parameters that are not right on those tabs, but most of them are. The ABS tab especially is a bit iffy, esp in this case.
For example, 760-03-01 is missing some bits (your value above has xxxx xx-- but the spreadsheet only has xxxx -- , so it would be nice if we could find the most up to date version of this sheet. But at any rate, TTA is listed to be xxx* on the screen shot below. Take the value "C" from your "F27C 764F" reading, and decode the C below, which mentions "without Trail Turn Assist". Change the C to a D and that activates TTA. Sequoia above though said to change the 5 to a D though, so I'm not sure which is right....![]()
Rewrite the 7 to D. It will look like this F27C-D64FHi Sequoia,
I've successfully done the first two steps but my ABS module has completely different number to yours.
You can keep redoing the 2 month free license. Thats what Ive been doing.2 month free..
thereafter 12$ / Year.
Fair enough. For the amount of times Im going to use it, the free is ok. If I was working on it multiple times a week, different story.But honestly, itās twelve dollars a year, and thereās a development team behind it. I donāt want to cheat them; Iām happy to pay the twelve dollars.
