Raptortugal
Portugal
Ranger Raptor 6g
I managed to remove the CAMERA AUX icon in 7D0-01-02 I left by default 2xxx instead of Axxx (2 being aux camera disabled).
I will also modify everything related to the CAMERA AUX in the IPMA by comparing with the original.
babaduk
Bart
Europe
Ranger Raptor 5th gen, Ranger Raptor 6th gen
anyone know how to enable 50/50 view camera?
any help much appreciated
It’s not in your manual, it’s not intended that way, so the dealer can’t repair anything. Everything is working as designed. And there is no coding for it in FORScan.
It may not be in the manual, but some modes, like Slippery, say press OK on restarts. It only lasts about 4 seconds.
sloon
Michal
Česká republika
Ford Ranger Raptor 3.0 V6, 2023
Can someone remind me where to find the codes for enabling the actual numerical temp for engine and oil in the dash display?
Digital Temp Gauge (With Alphabet C/H, E/F)IPC720-07-01xxxx-xx**-xxxx**=54
Minor Gauge Units (Numerical/ Alphabet C/H, E/F)IPC720-11-01xxxx-xxxx-*xxxAlphabet *=8 / Numerical *=A
Sequoia
Dan
Germany
Ranger Wildtrak 2023
Does anyone know if it’s possible to code the daytime running LEDs not to dim when the low beams are on?
craigc
craigc
Craig
Allen, TX
Now it would be brilliant to make the front camera activatable as well.
I've tried everything I know to try and have not yet been able to get the front camera at speed...
If anyone has had trouble getting the "reverse camera at speed", this is how I got it working on MY22 XLT
IPMA 706-02-02 xxxF CExx xx--
APIM 7D0-01-01 xxxx xxxx Fx--
APIM 7D0-01-02 Axxx xxxx xx--
APIM 7D0-01-04 xxxx FCxx xx--
APIM 7D0-02-02 xxx3 xxxx xx--
As always use at your own risk ??
I'll try to find some time this week to add this to the sheet
craigc
craigc
Craig
Allen, TX
It is like the truck knows you are on a freeway and automatically goes into Auto Resume mode for adaptive cruise control. Then when the car in front moves, it start to accelerate from a stop automatically. But, when on normal streets, it knows and when it comes to a stop it goes to Auto Stop and you have to either press the gas or kit OK on the steering wheel to have the truck start again when the car in front start to move.
I'm not positive, but I think it has to do with whether you step on the brake or it automatically stops you as traffic ahead slows/stops. In the city I tend to not trust the ACC stopping me gracefully enough and usually hit the brake with my foot and then I think that won't let me resume until over 20MPH.
Ragner
Victoria
2022 ranger XLT
Supervisor
It should be noted that 7D0-01-02 should be 2xxx xxxx xx-- instead of A..
This removed the button for auxiliary camera.
Antman450
Anthony
Reno, NV
2024 Ford Ranger Lariat
I just let the truck stop on its own when the car in front stops just like on the freeway. However, it does not Auto Resume and I have to hit the gas pedal or "Ok" on the wheel to get it to go again. It does not do this on the freeway and resumes on its own.
I was wondering if anyone knew how to set this with Forscan to do the same as on the freeway. I would imagine there is a setting somewhere for this. I do not however have the knowledge to figure it out.
Sequoia
Dan
Germany
I just searched my PDF of the modules. Maybe in BodyCM the point:
"Cruise Control" is set per default to: "Adaptive Cruise control, Stop&Go"
Maybe there is another option?
CarTuner
Australia
Next Gen Supercab Ranger XLT BiTurbo
Can someone let me know what works on Aussie Rangers?
Sorry if someone's asked this already, I'm lazy...
KiwiRaptor
New Zealand
MY22 Ford Ranger Raptor (Next Gen)
Mine's an NZ Raptor. Should be similar. Here's what I've got working so far.
Power Delivery (To Wheels) Gauge in Cluster
Turbo Boost Gauge in Cluster
Tow/Haul Mode
Trail Turn Assist
Auto Lock Doors on Motion
Lane Keep Assist Removal
Lane Change Blink Number
Enable Reverse Camera and Hitch View at Speed
Engine Temperature Gauge - Show Temp Value Below Gauge
Transmission Temperature Gauge - Show Temp Value Below Gauge
Fuel Gauge - E to F
Turn Off Seat Belt Reminders
TPMS Default Units - PSI
TPMS - Display tire temperature in addition to tire pressure
Frost Telltale (Below 5 deg) - Not sure if working, since it's summer.
cleffe
Cgrus
24 Ford Ranger Raptor
Can you switch Baja mode to allow 4A or 2H?
