dsmclark
Sam
Dorset
Ford Ranger Raptor
My truck was broken into back in January and the window that was smashed, since being replaced, no longer closes with the lock button. Anyone know how to relearn this function?
Also the active flaps on the intercooler hardly ever open even when its really hot. Is there anywhere in forscan to set the temps that they open and shut?
There is a window relearn for the stops. You might have to google how to do it though, because i dont know how to do it
KiwiRaptor
New Zealand
MY22 Ford Ranger Raptor (Next Gen)
I have them (Wildtrak!). I can activate it manually since I coded it. There is a button now. But it does not come on when blinking
@Sequoia How did you code it? Do you remember? I have an MY22 Ranger Raptor, and have been tinkering with things like this, and 50/50 View at Speed, etc, but can't get anything beyond Rear Camera at Speed working.
I guess with 50/50 or with L/R view on indicator, it more or less replicates the function of your mirrors, but it'd still be nice to have the option.
Cheers.
KiwiRaptor
New Zealand
Has anybody managed to get Onboard Scales working in a Ranger Raptor? I've managed to get a toggle option in one of the menus, but it doesn't do anything, so I suspect there's a couple of extra settings I need to change.
In theory, I'm assuming we should be able to get it going, since the VDM module measures rides height to instruct the Live Valve shocks how to behave.
dsmclark
Sam
Dorset
Ford Ranger Raptor
Just had to hold the window button up for 5 seconds. I don't know why I didn't think to google it before :facepalm:
Glad it was easy to find and worked out
ramiro_mdq
Ramiro
Mar del Plata, Argentina
Ranger Limited Plus 2025
Hi,
I have an argentinian Limited+ (3.0 V6 Diesel). I have been able to add many options using Forscan such as driving modes, TTA, instrument panel gauges, seatbelt message off, etc. However, there a couple of features which are still giving me headaches....
For those of you with LATAM or EU non-Raptor Rangers, have you been able to enable welcome lights and/or 360/zone-lighting?
For welcome/approach lights I have tried the modifications as explained in the spreadsheet but lights do not come up, even though that the option is enabled in the center screen.
For 360/zone lighting, I have been able to add the option in the center screen -and even enabled 360 lighting in BCM- but everything is grayed up....
@Sequoia , @renato23 , any luck of these features?
Thanks,
Ramiro
Goldylox22
Nick
Sacramento, CA
Self-Employed
About to start diving into FORscan myself but reading through these it seems insane that these aren’t available settings off the bat. Safety stuff like seatbelt dings make sense but things like basic cabin light control shouldn’t need a hoop to jump through when it’s already built in an an option.
renato23
Renato
Brazil
Ranger Black 2.0
Hi,
Thanks,
Ramiro
I was able to activate welcome lights on a friend's car last month. My car does not have the keyless entry system.
Sequoia
Dan
Germany
Ranger Wildtrak 2023
Cheers.
I coded it exactly as shown in the spreadsheet. Unfortunately, it just doesn’t work properly while driving. I do have the button now and can activate the 50/50 view, but the issue is that I can’t exit the view unless I’m driving fast enough for the cameras to deactivate. The little “X” to close the view doesn’t respond.
So something’s definitely not behaving as it should. Also, the turn signal camera activation doesn’t work either – even though I selected the trailer option in Sync 4. It seems like it’s partially working, but not in a usable way while driving.
@ramiro_mdq the welcome lights are working fine. But I deactivated it because the sensitive of the keyless go lock was degraded
ramiro_mdq
Ramiro
Hi guys,
After some investigation, I've found that some F150 and F250 users from Australia have been able to enable Zone Lighting by modifying these 3 modules: APIM, BCM and GWM. Local regulations in Australia seem to clash with Zone Lighting functionality so they had a recall to disable it.....
It seems like GWM (Gateway Module A) is the link between APIM and BCM, which I'm missing to get the power button in the Zone Lighting section of the screen to work. However, when trying to modify GWM's address 716-02-01 using as-built mode in Forscan, I get a "Service procedure has been interrupted" error. It seems like it's not being able to write in GWM module.
Has anyone else run into this issue?
Regards,
Ramiro
Ragner
Victoria
2022 ranger XLT
Supervisor
Hi guys,
Regards,
Ramiro
Hi Ramiro,
Zone lighting is activated here in Australia from factory. Do you mean welcome lighting? If so mine was easily activated via the spreadsheet inputs.
ramiro_mdq
Ramiro
Hi @Ragner , I mean Zone Lighting.
It seems like Australian F150 got a recall due to ADR related to zone lighting, so some users that lost the functionality during the recall wanted to enable it again. I don't know why this affected F150 and not Rangers.....
Check these links:
https://www.drive.com.au/news/fix-coming-for-ford-f-150-adr-breach/
https://www.f150gen14.com/forum/thr...to-fix-adr-recall-australian-f150-23my.27785/
I haven't been able to write into GWM for Zone Lighting activation, so this is the issue I'm currently trying to solve. I have also not been successful in enabling welcome lighting, but one thing at a time.....
renato23
Renato
Brazil
Ranger Black 2.0
Guys, after a long time trying I was finally able to make the OBDLink MX+ work on my MacBook M2 running Windows 10 via Parallels.
The trick is simple: you can’t use Mac’s bluetooth. I bought a cheap plug&play usb bluetooth adapter, connected it to my Parallels Windows machine and it worked like a charm!
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet Screenshot 2025-06-28 at 12.51.19
