Hande
Hannu
Estonia
Business Owner
Thank you for your replies, thats what I was afraid of….
How about disabling Normal drive mode - would that make Sport the default drive mode? 🤔
joordan
Italy
ranger wildtrak 2023
you would need to disable ECO too as the sequence is normal, eco, sport. but the trick should work. still not ideal as I won't drive my truck in sport all the time. and during winter time, I'd rather start with slippery mode
Hande
Hannu
Estonia
Business Owner
I think that RR does not have Eco mode 🤔
So that should work.
…I dont understand slippery mode, it takes engine sensitivity away when you need it most 🤔
How do you guys use it?
NOT_RAPTOR
Cleveland
Is there a way to make the remote window open feature also open the little back window too?
midnight270
NNJ
2025 Ranger Raptor CGM
I don't think so. People tried to make that switch a one touch like the other windows but it's not able to be. I think both those features relate to each other.
NOT_RAPTOR
Cleveland
Has anyone found a way to auto set the parking break when you go into park or turn the truck off?
Hande
Hannu
Estonia
Business Owner
Thakk you for your replies, thats what I was afraid of….
Replying to myself - does not work, when Normal is disabled it disables the whole drive mode system :confused:
No, I tried to disable normal and once you turn the truck off and restart, it errors because the ecu looks for normal, which is no longer available.
I did remove eco and add all the other drive modes except raptor, since I dont have that full time 4wd.
I actually dont have any 4wd, as my truck is rwd only, but all the drive modes work and it activates the diff lock and crawl modes, like a 4wd truck would. I tried them out in the yard to make sure stuff worked and they do. Lots of the modes feel similar so I dont know why so many options are available. Sand, crawl, and mud feel the same
Shrek The Raptor
George
atlanta
Slippery mode is designed to reduce throttle sensitivity in slippery conditions. So think snow/ice/etc where throttle input should be dampened to reduce slip. That’s why it auto enables 4a as well.
Perhaps that's because you're missing like half the drivetrain that makes those modes more capable?
That is very possible, ha ha ha.
And all we have is sand here so not a ton of places to try stuff out but missing the front half probably has a huge effect on how it works, ha ha ha
Khamsin
‘25 Ranger Raptor
Retired Army —> Public Sector
After I changed the modules I needed to cycle the ignition on and off a few times for it to work. You'll know it worked when you go into the Lighting settings for the truck and see "Glare-Free Lighting"
This might be the thing that finally gets me to fork around with this forscan stuff.
Has there been any movement/update on the nanny seatbelt screen that stays up for entirely too long? I really, really want that nag gone but the potential airbag ramifications deter me.
