Forscan success?
Stefk
Stefan
Alberta, Canada
2024 Ford Ranger XLT
Has anyone had success with Forscan or other types of software or tunes? Having a ton of issues with blindspot faults on my '24 XLT due to rural roads and the poor location of a connector being hammered by gravel.
Dealership says that the software is locked up tight and are unable to disable the blind spot feature in addition to permanently disabling stop/start. Any success or suggestions out there? These smart feature faults are becoming quite annoying.
Quick answer: no. But when I got my '25 about a year ago I couldn't use Forscan because my VIN was too new to be recognized. Maybe a month or so later a beta version was available that worked for me, and a short time later the main version was updated to include newer VINs. So if this is your issue give it a little time and/or send an email to the developer with your VIN.
That aside, I don't think you can use forscan to permanently disable auto start/stop unless that's changed for '26.
rugedraw
Javier
Miami, FL
Auto Sales
You can disabled blind spot assist here in the door modules:
Ford Ranger Forscan success? 1775748757850-sy
And here in the IPC:
Ford Ranger Forscan success? 1775748795721-tv
However, isn't there a way to just turn it off in the driver assist menu?
but no, no shutting off stupid a/s/s
daytoncarter
Dayton
Where is your hammered connector? Maybe buy some mud flaps, because I'm not realistically seeing how with the flaps any rocks would hit BSM components.
I’d protect the connector with maybe some sheet metal.
I wonder where the connector is?
Ford Ranger Forscan success? IMG_3777
Freedom Beast
James
2024 Ford Ranger XLT FX4
I have one
4Dtech a/s/s plug and play is the bomb. Works like a champ
like it actually stays running? i could get the symbol to turn off on the cluster but the system still turned the truck off at the lights unless you hit the button each time you started the truck
Shnarf1
WI
Ranger raptor
Mold Maker
Yes it stays running. At least for a few days now. I was looking at other stuff and and saw 1 more place to disable it. The other ones did nothing, but not sure what combination works. All of a sudden it was gone.
Thunder175
Tom
Northern Virginia
2026 Ford Ranger Lariat
Science and Engineering Technical Advisor
Was it completely disabled or still user selectable meaning you can turn it back on with the switch? There have been a few occasions where I actually turned it back on while sitting in a huge traffic back up due to an accident for example. I'm a little leery about making a bunch of separate code changes though so might just order the 4Dtech harness instead.
Shnarf1
WI
Ranger raptor
Mold Maker
Not completely sure. I will have to look closer after work today.
Magambi
Magambi
Kansas City, MO
2024 Ford Ranger Lariat
I turned off A/S/S completely with Forscan. It stays on all the time. If I want it, I can press the button to activate it. But the default is now to have it disabled.
