- Joined
- Feb 27, 2025
- Threads
- 37
- Messages
- 1,098
- Reaction score
- 1,668
- Location
- United States
- Vehicle(s)
- 2024 Ranger Raptor
- Occupation
- Electrical Engineer
- Thread starter
- #16
The aftermarket IC's are Bar and Plate vs. Tube and Fin. Tube and fin are lighter and tend to flow better at a given size, but require expensive machinery to manufacture on a mass scale. Tooling setup-cost is high with tube and fin, but manufacturing cost is low on a mass scale both from materials and labor, so that is why OE's use tube and fin.
Bar and plate are generally manufactured manually, they are heavier and don't flow as efficiently BUT add thermal mass. And you can achieve the same flow rates by using larger cores to compensate, so that's actually why all the aftermarket bar and plate intercoolers have much larger core volumes than the stock tube and fin units, they need the larger volumes to achieve the same flow rates and pressure drops as the tube and fin units.
The advantage comes in the much higher thermal mass and resulting increase in surface area both of which increase cooling performance at the expense of cost, weight and size, which off sets their deficiencies in flow per a given volume. Turbos can compensate for added heat by increasing boost, in fact the Ford PCM tuning targets air density, not boost pressure.
It will increase boost pressure (to within operating limits of the turbos) as the IC heats up to achieve the targeted air density at a given load. The downside is that increasing boost pressure also increases heat and back pressure on the exhaust side, so as boost pressure increases, it drives the turbos further out of their efficiency island (thus increasing exhaust back pressure and turbo heat loading), so you can only increase boost to compensate for heat to a limited degree.
If you can achieve 30~40F cooler charge temps at the same pressure drop with an aftermarket IC, you're reducing the load on the turbos because they don't need to be driven as hard to achieve the target air density. This will lower heat and back pressure, allowing for making power more consistently and efficiently.
This really only matters at sustained high load. For short bursts of power or typical uses, it's not relevant and the factor IC is quite optimal for those applications. But for 1/4-mile passes, hot lapping, racing or any sustained WOT you will see benefits of an IC upgrade, especially in hot weather where the differences are most noticeable.
OE's don't use bar and plate because of cost, both in materials and manufacturing labor. They are much more expensive to manufacture as it's still largely a manual welding process and require much more material per a unit to produce, but if your after performance and durability, bar and plate is worth the cost and weight. Also the added mass acts like a thermal flywheel, creating a lag that helps maintain stable charge temps during very high load transients.
The downside is that when bar and plate do heat soak, they take longer to cool off due to the mass, but generally, they are MUCH harder to actually get to the point of heat soak AND the added surface area tends to off-set most of the added mass to the point that they seem to actually cool off about as fast as tube and fin in practice under real-world driving.
There's a lot of here say and theory on this or that, but in practice, generally larger sized bar and plate IC's tend to significantly outperform OE tube and fin intercoolers due the combination of overall properties.
Is it worth the extra cost and ~15 lbs more than stock? Depends on your use cases.
