I left a 3 star detailed review that amazingly hasn't been posted to there site. Quality of the lights and brightness are good, however the 7/16" drill bit they require to push the connector thru tore up my grill and the light clearly wont cover them, no matter what angle I held the drill.
POOR design for a tight space. They should've either used a smaller connection or bare wires going thru. Now I will have to use some spot putty to fix it. These pics are after I used various paints mixed to camouflage the missing paint and gouged plastic.
Curious, I have not installed mine yet, but I did plan to follow their recommended masking of the holes seen in their install video. Did you use the masking tape and still get that sort of damage?
It looked like it worked in the video.
These are screen caps from their install video.
Ford Ranger New Ranger Raptor amber grill lights released by F150LEDs IMG_5827
Ford Ranger New Ranger Raptor amber grill lights released by F150LEDs IMG_5828
iBrad81
Brad
Cleveland Oh
A little tip is that upper piece separates from the grill and you could drill from the rear
Fawnbuster
Indiana
Yes sir, masked it, made sure the bit was the correct size. If I had it all to do over again I would remove the grill and drill the holes from the back side, that would solve all the risks of scratching the front of the grill. I even used a 1/4" bit to drill a pilot hole in the last 2 holes, the 7/16 bit still damaged it, just not quite as bad.
Them saying that you might scratch the grill but not to worry, the light would cover it. Not the case since the scratches are in front of the light. The plastic in the back of the slots in the grill is so thin it was cutting the top and bottom behind the lights. The video also says you can reach in and push the light up and hold for a bit to get the adhesive to stick. That's impossible to do, the lights take up all of the space. I couldn't even get a thin putty knife under it. He must've either been using a different light or a different grill, you can see by my photos that there is no room to get a finger under it.
Tony VanZant
Tony
Georgia
24 Ford Raptor
N/A
The Spec And according to a Online chat with them the Lights (led etc) are the same as the F-150 version the only difference is the Housing. and hey they are only $140 buck more.
Same lights.
Baseball0618
PA
I drilled smaller pilot holes first because the drill bit required can barely pass through opening that the marker lights sits in. The pilot holes make it a bit easier for the 7/16 bit to pass through the grill without marring it. If they made the connections slightly smaller or bare wires that could be attached to a separate harness it would make a lot more sense. The lights do look great though and seem to be of high quality.
Ford Ranger New Ranger Raptor amber grill lights released by F150LEDs thumbnail_IMG_6207
ColeTrainsRR
Cole
Minnesota
E-Tec 3
Got mine in and my signature Lux DRL boards got here today. Also got my amber oem style fog lights as well.
Ford Ranger New Ranger Raptor amber grill lights released by F150LEDs 20250929_034140
Ford Ranger New Ranger Raptor amber grill lights released by F150LEDs 20250929_034306
Ford Ranger New Ranger Raptor amber grill lights released by F150LEDs 20250929_034247
GLW
Missouri
You could cut off the connectors and drill much smaller holes in the grill to run just the wire though the grill and then splice the wire back into the connector or, what I typically do is, cut off all connectors and just splice where I need to using waterproof shrink connectors. This eliminates drilling big holes and having a bunch of left over wire to bundle and hide. I think it’s much easier than drilling and managing more than double the wire needed.
ColeTrainsRR
Cole
Minnesota
E-Tec 3
Then you run into elimination of the waterproof aspect
Reactions: GLW
YukonRanger
Yukon
Damn, was going to order these but they don't color match
The search for the perfect grill lights continues.
I even have 12V DRL pre wired to the grill...just waiting the correct product.
I want water proof, flush mount, color matching amber lights in the top 3 slots or 4 X Diamond shape for the top row Mid grill
Waterproof, UV resistant, quality cabling
Almost a grand slam F150 LED's but not quite.
What do you mean by color match?
Amber is Amber right? I am picturing maybe brighter or dimmer, but Amber is Amber?
ColeTrainsRR
Cole
Minnesota
E-Tec 3
I followed the recommendation in the install video. It is very tight for the recommended drill bit, but it is doable. Just take your time.
Man I wish HPR was available in '25... ford dropped the ball
YukonRanger
Yukon
They are slightly oranger than the rest of the amber LED's...look at the photos
it's not a terrible look, but it is not a match
