jeffers
Jeffrey
Nevada
2024 Ranger FX4, Mk7 GTI
Don't do the work yourself, go into the service department and get the paperwork.
FossIsleBC
Victoria, BC
2024 Ford Ranger XL
I cant find it on either website, and its not showing in the App
What vehicles does it apply to? Specific build date range? All trims?
Axg1040
Axg1040
Virginia
It is showing in my App under recalls. When I run my VIN on NHTSA and Ford Recall site it comes up as well. It is odd no span of production dates.
Ford Ranger NHTSA Recall 24V770: Separation of Front Upper Control Arm (UCA) IMG_7665
Axg1040
Axg1040
Virginia
Of course but I’d rather be proactive and make sure it isn’t loose and end up in a ditch waiting for repairs.
ducktapeonmydesk
VW Golf R
Did a little research and from what I can tell the UCA ball joint nuts have torque specs of 46ftlbs. Don’t quote me on that. Part # W717969-S440 (ball joint nut for RR) is readily available but is a single use part. Odd they say remedy not available yet. Might be more to it. Almost want to put a torque wrench on mine to make sure but also don’t want to wreck the thread locker…
46ft lbs is correct per the manual. The nut is a one time use part. If removed, it must be replaced.
Ag3ntC00p3r
Product Manager
NHTSA was just updated with the document that lists build dates impacted.
Thanks for finding and posting this. Makes me feel a lot better about this extended trip I’m on.
EDIT, the recall appears to be for a different nut that I wrote about, I assumed it was the top one on the UCA. Sorry for the confusion, but it wouldn’t hurt to check the upper ones anyway. JD
Deleted previous content that was just wrong,
Ford Ranger NHTSA Recall 24V770: Separation of Front Upper Control Arm (UCA) IMG_7137
jeffers
Jeffrey
Nevada
21mm, oh yeah, this is an Australian truck. Are the engine bolts all metric or is it a hodgepodge?
I not in those build dates so I am good :)
Catalyst
Justin
Bend, OR USA
Network Engineer
I read the recall as part #7 in that exploded diagram... UCA to knuckle ball joint nut.
Catalyst
Justin
Bend, OR USA
Network Engineer
Thanks for the clarification about which nut, I edited my post, I was confused obviously. To be safe I am going to delete the bogus info…. ;(
