FreezingFlatlander
Montana
2021 Ford F150 4x4 3.5 Ecoboost
Bolting the J-Brace itself in place is the easy part. After the commotion of peeling enough of the wheel well liner back to gain access and cutting out the metal on the corner of the box sheet metal to allow the steel backing plate to slide up the vertical channel of the box structure, the bolting the J-Brace in place went well. The J-Brace is a very stout piece of metal.
Ford Ranger Part II, J-Brace Installation-Yikes IMG_6694
Ford Ranger Part II, J-Brace Installation-Yikes IMG_6716
Ford Ranger Part II, J-Brace Installation-Yikes IMG_6720
tbalt14
Tom
IL
2022 Ford Ranger
Electronic technician
So there are no bolts to replace the rivets that were removed?
tbalt14
Tom
IL
2022 Ford Ranger
And with that question what holds the new top bolt in place? Just a washer and nut on the other side?
I'm assuming there is a 2 layer vertical with a nut welded to the inside piece he slid up through the hole. The bolt then pinches the original metal.
FreezingFlatlander
FreezingFlatlander
Montana
To answer questions-Replacement rivets came with the kit but I had not installed them yet when the pictures were taken. And there were two nuts welded to plate that you push up inside the vertical channel that the bolts thread into so that the bracket is then secured to the vertical portion of the box structure. I have not said that this brace is necessary for everyone as maybe it isn't but I choose to install it as I do drive on really rough roads and may put a tool box on the front of the box, I assume Ford made this J-Brace kit for a reason.
Zangor
Zangor
This should be a Manufacturer Recall fix- Truck buyers don't anticipate that you need to install this to use a toolbox or a cap/canopy.
Its a bit of false advertising in my opinion that the trucks need this to do basic truck things
engus13
Clemmons, NC
2024 Ford Ranger Lariat Fx4
I doesn't appear that you needed to remove the original rivets that you did. It doesn't look like the bracket interferes with that section. It looks like the only modification would be cutting that corners piece out. Can you confirm?
FreezingFlatlander
FreezingFlatlander
Montana
The steel Pop Rivets did have to be removed as stated in the instructions as they were among the many other fasteners holding the wheel well liners in place. For some reason these rivets were made of a very hard material and it took some effort with the Sawsall using a carbide blade to cut them off. Without removing the rivets one would not have been able to access the area where the J-Brace was to be installed.
engus13
Clemmons, NC
Thanks, make sense now.
24'Ranger
Kevin
MN
2009 Vibe AWD, 2019 Outback, 2024 Ranger?
Are J-braces required on full-size trucks like the F-150?
LFRR13
En Why Sea
Honda Ridgeline
Per my dealer, the "TSB/recall" is not on Raptors and the J-braces are back-ordered and being drop-shipped from manufacturer to dealer directly. No word on availability.
