Port and direct injection
Bmadda
6gBronco, 4gBronco
Mechanic
Sorry to bring this thread back to life, but has it been definitively determined what injection system the 3.0 TT Ecoboost engine in the 2024 Ford Ranger has? Direct Injection only? Or Port and Direct?
Asking for a friend :)
DI only
Ford Ranger Port and direct injection 3lfuel
PhoenixRanger
R
Phoenix Arizona
Bronco 2 dr. OB/AMB 2.7L, Ranger Raptor Carbonized Grey
Lets make this simple; https://media.ford.com/content/dam/fordmedia/North America/US/product/2024/ranger/2024 Ford Ranger Raptor Specs.pdf
ENGINE
3.0-liter EcoBoost® V6
Configuration Valvetrain Bore x stroke Twin-turbocharged and intercooled V6, compacted graphite iron block, aluminum heads
DOHC, four valves per cylinder, twin independent variable camshaft timing
Ignition Coil on plug
3.36 x 3.38 inches (85.4 mm x 86.0 mm)
Displacement Compression ratio 10.5:1
Recommended fuel 91 octane
180.0 cubic inches (2,949 cubic centimeters)
Fuel capacity 20.3 gallons
*****Fuel delivery Port fuel and direct injection******
Power 405 horsepower**
Torque 430 lb.-ft.
Hence, the debate.
RANGER/HOBB
THE WORLD
Retired USAF
https://www.caranddriver.com/ford/ranger-raptor/specs
https://www.motortrend.com/news/2024-ford-ranger-raptor-pros-cons-review/
https://www.ford.com/trucks/ranger/models/ranger-raptor/
And there’s more……….there’s no debate……..👍🇺🇸
Engine
Engine Specifications
Engine type2.3L EcoBoost® I-42.7L EcoBoost®**3.0L EcoBoost®
Auto Start/Stop TechnologyStandardStandardStandard
Engine Control SystemPCMPCMPCM
Horsepower (SAE net @ rpm)270315405
Torque (lb.-ft. @ rpm)310 lb.-ft.400 lb.-ft.430 lb.-ft.
Compression ratio10.1:110.0:110.5:1
Bore (in.)3.45 in.3.267 in.3.36 in.
Stroke (in.)3.7 in.3.267 in.3.38 in.
Displacement (cu. in.)140 cu in.165 cu. in.180 cu. in.
Fuel deliveryDirect InjectionPort fuel and direct injectionPort fuel and direct injection
Recommended Fuel87 Octane87 Octane91 Octane
Oil Capacity6.2 quartsN/AN/A
EPA-Estimated Ratings - 4x2*N/AN/AN/A
EPA-Estimated Ratings - 4x4*N/AN/AN/A
EPA-Estimated Ratings - Raptor*N/AN/AN/A
Transmission typeElectronic 10-speed automaticElectronic 10-speed automaticElectronic 10-speed automatic
Transmission - Tow/HaulStandardStandardStandard
Transmission - SelectShift® w/ Progressive Range SelectStandardStandardStandard
Engine block materialAluminumCompacted Graphite IronCompacted Graphite Iron
Cylinder head materialAluminumAluminumAluminum
*Actual mileage will vary.
**Late Availability - Summer 2024
I’ll believe Ford and it subsidiaries. Posting photos without any supporting documentation and evidence is inconclusive to say the very least.👍🇺🇸
Bmadda
6gBronco, 4gBronco
Mechanic
PhoenixRanger
R
Phoenix Arizona
Yes, seems odd that Ford would not have corrected that error after this long?
Bmadda
6gBronco, 4gBronco
Mechanic
Parts manual pics 3.0L vs 2.7 (which is where the confusion started)
RANGER/HOBB
THE WORLD
Retired USAF
Let’s see, you’re utilizing a 2023 and 2020 parts manual……………Now show us the 2024 3.0L Ranger Raptor parts and technical service manual.
The 2023 3.0L V6, is direct injection used in the;
  • Ford Explorer
  • Lincoln Aviator
  • Lincoln Continental
  • Lincoln MKZ
The 2023 3.0L V6 used in the Bronco is; direct fuel injection.
Not the same engine, this is their next gen engine and You‘re not displaying the 2024 3.0L V6 Ranger Raptor engine, its parts or technical service manual.
This is what you’re referencing specification from;
https://www.ford.com/suvs/bronco/2023/models/bronco-raptor/
2023 3.0L V6 Bronco.
Bmadda
6gBronco, 4gBronco
Mechanic
  • Ford Explorer
  • Lincoln Aviator
  • Lincoln MKZ
What I posted above is the fiche for my VIN. The 2.7 Pic is for a 22 Bronco. Neither Braptor nor RR has the port/DI. Just pop your hood dude!
Bmadda
6gBronco, 4gBronco
Mechanic
appears that Ranger with 2.7L has DI and port. RR does not tho, and neither does Braptor
Ford Ranger Port and direct injection rngr27fuel
Actual pics underneath my manifold from borescope...count em!
Ford Ranger Port and direct injection 20240920121247
Ford Ranger Port and direct injection 20240920121255
RacerX
Bronco
Ford had the same typo on the Bronco Raptor spec sheet.
anti-lag
Steven
Louisiana, USA
I was in denial for awhile too, but unfortunately the 3.0 in the RR is DI only. It is frustrating that Ford has let this typo persist for so long.
I did the same parts catalog exercise and all signs pointed to DI only. You can't tell by looking under the hood without a borescope, credit to @Bmadda for taking pics. When I was at Raptor Assault a few weeks ago they had an RR chassis in the lobby, so I snapped some pic, no port injectors..
Ford Ranger Port and direct injection PXL_20240906_140018373
Ford Ranger Port and direct injection PXL_20240906_223306617
