Possible boost leak but no codes: Now, Shaft Play Update
jordantii
Jordan
Tampa Bay
www.straptacademy.com
2025 RR
Not sure what this sound is but @RRaptorscallion0331 made a post about the same sound. Truck has just under 6k miles and no codes. Could this just be spool or possibly a bearing in one of the turbo's? Really don't want to go to the dealer if I can avoid it.
Anyone else have the same sound? @Goosetuned have you ever heard this before?
And man I need to clean the interior...
Goosetuned
Gold Sponsor
Winfield
AZ, NM, TX
Professional Tuner
Have you done any charge tubes?
RRaptorscallion0331
Colin
Hey thanks for starting this thread, dealership says they need at least 24hrs before they can do anything… to me that doesn’t make sense, just say “we’re backed up, you’d be better off bringing it in tomorrow “ there’s a mechanic shop that has ASE certified technicians and says they specialize in fords but if they only rely on a diagnostic scanner it may not show anything? I’m gonna give them a call and see, hey @Goosetuned , if I hooked up forscan to it is it possible I would see anything of importance? My boost tops out at 16psi and idles like 4-6 inHg is that the norm?
jordantii
jordantii
Jordan
Tampa Bay
2025 RR
This seems to be the norm at the two dealers I've been to. You schedule an appointment and the truck sits on their lot for 1-2 days before they look at it. I checked for codes and have none. If it's a bearing in the turbo's I would think you would hear it after you shut down since the turbos would still be spinning unless it is load dependent. Which it seems like it is. I know the shop foreman at my dealer and will see if I can get him to drive with me.
RRaptorscallion0331
Colin
10-4, I even tried telling the service adviser that I’m a silver tier member lol… I’m goin to take it into a local shop that said they could take a look at it on Friday; no warranty (I’m at 31.5k so not a dealbreaker) and $185 diagnostic fee (which I would pay in under the table cash if the dealership could see me sooner). Next option is going to a performance tuning shop and seeing if they’ll fix it in the process of installing a tune… I dunno I just don’t want to have the annoying sound at Texas Raptor Run next week..
jordantii
jordantii
Jordan
Tampa Bay
2025 RR
All they need to do is a boost leak test. Either with smoke or just compressed air and listen. Then spray with soapy water. If I can’t get in to the the shop foreman this week I’ll check all the connections myself.
It would be nice to know what the boost levels should be. It’s not a fixed amount, it’s based on conditions. But 16 sounds close.
RRaptorscallion0331
Colin
Just got back from the performance place, he looked under the hood while I rev’d it up but he noticed that my BOV was pretty loud and sensitive given that its stock. So either the diaphragm in the BOV went out, or it’s loud because it’s indicative of something else. Based on the hoses I’ve inspected when installing then uninstalling my CAI, it’s either hot side of passenger turbo, or the last leg of hose from airbox to driver side turbo, or the hot side of the driver turbo, or who tf knows… anyways, I won’t know anything else until Friday when the local shop takes a look at it.
jordantii
jordantii
Jordan
Tampa Bay
2025 RR
Cool let me know what you find out and I'll do tha same.
my buddy will be there too. i am so envious of you guys. my buddy said raptors on the rockies was awesome and he cannot wait till the texas raptor run.
take pics and put them up, please.
RRaptorscallion0331
Colin
This will be my first one, so I’m super stoked to learn what it’s all about, good idea! I’ll post a thread when I get back.
Goosetuned
Gold Sponsor
Winfield
AZ, NM, TX
Professional Tuner
Boost seems a bit low, hard to say though with altitude.
I'm not sure forscan will help you much. If you do just look at tip/load actual vs desired. Make sure it's hitting its targets
jordantii
jordantii
Jordan
Tampa Bay
2025 RR
What should it be at sea level with intake temps in the 120-130 range? I’m in FL. I’m guessing you have never heard that sound in the Ranger Raptor?
Shrek The Raptor
George
atlanta
I’m north of Atlanta, just went out and did a few test hits to try to get the tires to break traction (different thread) and I hit 20-21 psi per the dash in sport mode. Intake temps were ~100-110, and I’m at 1200 feet above sea level
jordantii
jordantii
Jordan
Tampa Bay
2025 RR
I saw 18 psi at sea level 113 intake temps. Stock tune, normal mode.
