josephp732
There are two metal transmission lines running along the passenger side of the transmission. There is a bracket on that side that needs to be unbolted. The lines then cross over the front of the transmission pan, running directly along the area where the front pan bolts are located. They curve upward on the driver’s side, where another bracket secures both lines to the transmission with a single bolt. Simply unbolt that bracket and pull the lines out of the transmission. Each line has two O-rings. Very little fluid came out when I removed the lines.That's awesome! A few years ago I would have totally jumped on doing this myself, but I've had some bad luck with vehicles lately and have gotten in over my head or caused more harm than good...
Curious, when disconnecting the transmission lines, do you have to do any sort of bleeding of air after reconnecting them post-fluid change? Thanks for sharing your experience
. JK.
