- Joined
- Feb 27, 2025
- Threads
- 36
- Messages
- 1,020
- Reaction score
- 1,513
- Location
- United States
- Vehicle(s)
- 2024 Ranger Raptor
- Occupation
- Electrical Engineer
- Thread starter
- #1
Goal: enhancing bed utility with minimal amount of weight for off-roading to secure smaller items (i.e., cargo totes, traction mats, shovels etc.) and for practical uses (i.e., secure a stack of 8 or 10 foot 2x4s so they dont slide out of the bed when hauling items longer than the bed).
Each track strip is only 2.5lbs. Mounting hardware is ~2-3 additional lbs. Total is weight gain is only 12-13lbs.
Strips were placed in a slightly staggered grid. So almost evenly spaced, with the two center strips being just slightly closer together than the outer. This allows me to secure long and narrow items using just two adjacent strips or larger wider items using every other or two most outer strips.
Straps can go across or in an x-pattern depending on the cargo.
4x strips of 4 foot long US Cargo Control standard L-Track. Each strip has 10x 1/4in stainless screws I also got from US Cargo Control in their mounting hardware kit, but I opted to not use the nuts / washers due to the difficulty and in some cases impossibility of getting them on from underneath.
I instead paired them with zinc plated carbon steel plus nuts i got from a separate vendor, also 1/4in obviously. Why buy the screw kits and waste a few extra bucks instead of buying screws separately elsewhere? US Cargo Control used milspec 100 degree countersunk taper, not 90 degree taper of most counter sunk screws. 100 degree are harder to find and more expensive, so buying the screws separately was a pain and I didnt mind wasting $20 for the convenience of buying them with nuts and washers I didn't use.
