Ranger raptor forscan ride height calibration
Jmerr94
Jordan
UK
Next gen ranger raptor V6
Does anyone know how easy it is to recalibrate ride height using forscan? Looking at fittings 35’s and front lift but will need to recalibrate the ride height for the active valves. Thanks
Deleted member 6842
From what I understand, changing the ride height in Forscan doesn't change the suspension as that is hardware dependent, not software. However, it ensures that the driving assistant features that uses the front facing camera doesn't trigger needlessly.
But the setting is easy to find in Forscan and the height is either in inches or metric. I don't have my laptop in front of me, but you shouldn't have an issue finding it.
JN75
Jens
Germany
It is easy to calibrate the high. I have done it with forscan Lite on my IPhone. You can also measure the difference bevor and after the calibration with forscan for each wheel.
Jmerr94
Jordan
UK
what really appreciate it if you could give me a step by step instruction whenever you get a chance. This would be my first time using the software so any guidance would be much appreciated. Thanks
Deleted member 6842
Hopefully someone here can help. I am currently travelling and won't have access to the truck for the next two weeks.
BigMeatsBronco
Allan
Oregon
self
this sounds great
Yague
Ivan
Santos, SP Brasil
Ranger Raptor 2024
Pilot
Good evening…
Anyone knows on what module the height adjust is possible?
Regards
