RCMUSTANG's Magnetic FX4
ulev1st
Don
West Tn
2019 Ranger CC FX4 ,2012 F250 Lariat FX4, 2017 Shelby GT350, 14 Ford Focus
Retire Marine and Refinery Operator
Update to the optimized throttle body. As expected on the way to work my instant MPG gauge was showing higher than normal on the same route. I'm reaching a higher speed with the same amount of throttle applied. It helping the low end as it's supposed to. I expect to see the mileage increase a bit like it did on my Fusion.
Looks like a good mod to do.. where did you source this from? Did you also do the blow off valve?
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
1989 Mustang 2017 Fusion
Cordova motorsports. It already have the stock bypass valve with the GFB. Anything else is unnecessary to me.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
What GFB part number is that? Awesome truck BTW!
Thanks. there should be a link in one of the 2 threads for it through Panda.
ulev1st
Don
West Tn
Since you have some background … is this the unit that they offer for the 2.3 Mustang cause I emailed them and they couldn't tell me if it fit the Ranger..is it a direct swap?
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
The actual housing is the same but the electronics is different. After the TSB it did not like it at all. I had to go back to the stock one. The best thing to do is get a new Ranger one from Ford and have them port that one. I'm going to get one from Ford but I'm having it bored out to 64.45 mm. Stock is like 58-59 mm.
FatMan
Alexander
New York
2019 Ranger XLT. 2015 Dodge Charger SE
Can you post conn joe's ebay username? Im trying to find him on ebay with no luck
Doc
Doc
Live oak fla
2024 STX, 2020 HPP Mustang, 2024 Subaru WRX
Jomical o
Under
2019 ford ranger raptor Mat finish grill upgrade w/logo
ulev1st
Don
West Tn
Keeps us all in the loop on that please...
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Will do.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Zero reason to complain about the oil change. Even if I wasn't doing it on my lift it's still easy. The skid plate and flap is a complete non issue. Only thing of note is where to put the pan when you remove the filter. It's further back with the little drain flap. 15mm for the skid plate bolts and the drain plug.
Ford Ranger RCMUSTANG's Magnetic FX4 20190327_153525
Ford Ranger RCMUSTANG's Magnetic FX4 20190327_155043
Ford Ranger RCMUSTANG's Magnetic FX4 20190327_155320
Ford Ranger RCMUSTANG's Magnetic FX4 20190327_161325
Ford Ranger RCMUSTANG's Magnetic FX4 20190327_161335
Roofhopper
Ted
Fairfield OH
2019 Ford Ranger XLT FX4
HVAC Service Manager
Outstanding! Thanks for the info
Randy2400h
Randy
2019 Ford Ranger Lariat Sport FX4, 2015 Ford Edge Sport
Thanks for the pics from the oil change. Hitting the 1500 mile mark next week and I’m going to change oil/filter at the same time I go back through to recheck the torque on everything that was touched during the BDS lift install.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Installed a set of Fabtech rear shocks. Took away some of the stiffness compared to stock. It matches the front more now with the leveling kit. Not as jarring. FTS7265 and picked up a pair of Pro Comp shock boots as they don't come with any. 20 minute job max.
Ford Ranger RCMUSTANG's Magnetic FX4 20190331_092238
