Rear end lowering?
Rangerjimm
2025 Ranger Lariat 2.3
Instead of a lift and larger tires I would like to lower the rear end slightly so the truck is level and stay with the standard size tires and wheels. This way no alignment and front suspension issues. are there any kits out there to do this?
Aircraft examiner
I almost always do the same and will one my warranty is over.
Are we spring over or spring under the rear axle? That will effect what you have to do to lower the rear end. I just lowered my 04 ranger a few months back and had to flip the rear spring hangers and remove the blocks above the rear axle but it gave me about 5 inches of lowering
Awirez
As long as you don't plan on towing much...
Spring over.
Ford Ranger Rear end lowering? 1742426367472-uy
Quick Google...
American Trucks
Ford Ranger Rear end lowering? 1742426518142-20
jedadiah
Jed
Kentucky
On the 5G, lowering the rear end a little was very difficult. I believe our trucks are similar. You can move the axle, but it is a big drop, which would mean lowering the front if level is the goal.
Rangerjimm
Some new leafs or just weight in the bed might be better. Thanks
Aircraft examiner
So they are like the old rangers. Flip the spring hangers or flip the spring plates which is like a 5 inch drop, as noted in the post above. Bummer
Rangerjimm
Crap, thats too much.
Aircraft examiner
Flipping the hangers should only be around 2, maybe 3. I did that on my 04 ranger but that requires grinding the rivets off and using bolts to remount the spring hanger to the frame.
Moving the spring from above the axle to under is like a 5 inch drop
Aircraft examiner
Ford Ranger Rear end lowering? IMG_1393
This was stock height
Ford Ranger Rear end lowering? 20241110_131005
This is with the hanger flipped and the factory 2 inch lift block removed (this truck is an edge so it had a 2 inch factory lift)
jazpdx
jim
Portland
A few sacks of sand. That’s too easy
Rangerjimm
Campingnut
Alberta
2025 Ford F350 DRW soon daily ford ranger
Mechanic
Did anybody ever find a way to lower the rear 1 to 2 inches
Michael9218
Michael
Woodstock, Ga
2025 Ford Ranger XLT 2WD
I suppose you could flip the axle and then add lift springs to get a modest 2-3" drop. The problem you'll always run into is the suspension travel. Any drop will come with a commensurate reduction in suspension travel.
Rangerjimm
Thats not going to do it. My 230 lb self can stand on the rear bumper and it doesnt move.
If wanting to drop the tail an inch or two, the cheap and easy way, is simply toss a few sandbags in the bed, that will do the trick.
Ford Ranger Rear end lowering? IMG_6762
You can even ones that look pretty decent.
Ford Ranger Rear end lowering? 1776477965120-dy
