Retractable Tonneau
Rousseb90
Pittsburgh
24 Range Raptor
Anybody install a retractable tonneau on their RR yet? I read about fitment issues with the Retrax covers. Ford sells a rebranded retrax, I wonder if the same issues exist. I’m strictly looking for a retractable cover with the T slots on the rails.
jrRaptor
Maize, KS
That's the one I've got.
See thread here.
jrRaptor
Maize, KS
I haven't had time to contact them so, no.
Supernaut
Taylor
Washington, D.C.
Yes it's a Raptor. There is a video of someone installing the X4S which is the same cover without the T-Slots on Youtube: Here is a picture of the X4TS installed on my truck.
BrrRaptor
Raleigh Nc.
Thinking of getting the same x4ts. How do you like it? How's it do at keeping water out?
Critical Habitat
Twin Cities, MN
I got the Bak Revolver X4TS has the t-slots. Its a rollup hardcover.
I ordered the X4tS Thursday afternoon, after someone mentioned the Realtruck site prices increased to $1,630, but the same from their Realtruck site on amazon was $1,430. Shipped late Thursday and already out to my local UPS carrier for delivery.
Still expensive, roll-up not retractable, but I saw one without the slots at the custom shop and liked it. Was not confident in having the retractable in cold winter climate, but it may work well for others.
Will wait to order the actual rack system
Critical Habitat
Twin Cities, MN
Update BAK X4tS delivered, ordered Thurs afternoon. Will try to install in the next couple days and then see what rack accessories I might need to carry my windsurf board and mast or my stand-up paddleboard.
Supernaut
Taylor
Washington, D.C.
So far so good. No complaints. It does let a little water in around the tailgate. Could probably add in some sort of weather seal. But it's not a lot and it doesn't seem to be an issue as the water doesn't flood the bed it sticks to the tailgate area and drains out.
Critical Habitat
Twin Cities, MN
So far so good.
I installed my X4tS last night. Took me around 1 hour. I like that the tracked version does not have the little plastic end piece fillers at the tailgate that the X4S install video showed where the plastic clips were broken on delivery.
Drove in the rain for coffee this morning and only water intrusion was a little bit of dripping inside the tailgate at one point on driver's side. May loosen bolts and adjust so the rear seal makes better contact there. Instructions were pretty good, except said it required a T40 but the bolt was actually T30.
The straps are a little flimsy and I don't like that it does not snug-up closer to the back window, as the X4S install video in this thread mentioned. Planning to get bolts to thread into bolt holes closer to the cab to attach the straps.
Hman
Idaho
Ford F150 Raptor, BMW X7
I used my ford rewards points to get the retractable one off their website and had it installed at the dealer.
Full-size no more
2020 1500 AT4-gone
That is exactly what I’m looking to do eventually. How difficult do you estimate it to be to remove?
