Stock Bumper Winch Plate
nSTIg8r
NC
2025 Ranger Raptor 2006 Subaru WRX STI
PTYSean
Panama
I bought this one.
https://www.sahara4x4.com/b2c/productos/15/2/333/22
the difference from the one in the link is that it has a mount for the radar on the front.
The European versions like the one I bought and the one you are looking at above are made for the euro version Raptor and have some differences in bolt placement and fit. You will likely have to get some welding done.
I have no issues with weight on the front.
Ford Ranger Stock Bumper Winch Plate IMG_2188
nSTIg8r
nSTIg8r
NC
I bought this one.
What winch are you running?
PTYSean
Panama
Warn Zeon 10 88990 12 Volt Electric; 10000 Pound Line Winch
MuleMarine
2024 Ranger XLT Sport
Anyone know if the frame rails/mounts are the same for the non-raptor Ford? I've been passively looking for a winch plate mount without a lot of luck.
nSTIg8r
nSTIg8r
NC
Sahara4x4 lists them as Ranger Raptor specific...... I'm guessing that they are model specific so you may want to reach out to them directly.
BrrRaptor
Raleigh Nc.
I bought this one.
How do you freespool your winch? Doesn't look like you can access the winch and engage the freespool?
rocsteady
New Jersey
Federal LEO
Looks like a very clean install. I would love to have a winch on mine but everything that blocks airflow gives me pause. It doesn't appear that yours blocks much, seems to sit down where there was just skid plate previously.
Sam Patterson
Sam
Nevada
Ranger Raptor on order
I bought this one.
What modifications did you have to do for this to fit?
PTYSean
Panama
As far as modifications, to be honest I don’t know exactly. I had it done in a shop. There were some changes to the winch plate due to it being from Europe and they had to cut the front bumper. There was no impact to the cameras or the radar. Both work fine.
as far as air intake, the AAC radar is already taking up a portion of the space and the winch sits lower, in the bumper. I can’t say for sure but it doesn’t appear that there would be too much impact on the intercooler.
My main concern was having a winch while not putting too much additional weight up front with a full replacement winch ready bumper. This was the best option I found. Total additional weight added upfront was 115.8 lbs (winch 90lbs, plate 25lbs) less whatever they cut away (probably no more than 5 lbs).
The skid plate wasn’t modified.
BrrRaptor
Raleigh Nc.
You say the winch weight is 90lbs?
I think i found the same winch on Amazon and it claims in the specs the weight is 25lbs.
Warn 88990 ZEON 10 Winch with Wire Rope - 10000 lb. Capacity https://a.co/d/7YdkMTo
Sam Patterson
Sam
Nevada
Thank you! The hidden winch mounts for the Broncos you had to cut a coolant hose to tge oil cooler on the 2.7 engines and cut some brackets off the frame so I stayed away from them.
