Techron fuel additives
Trimjb
Tennessee
2024 Ranger FX4
Since Tier 1 fuels are scarce around me I will start using Chevron Techron additive.
There are 3 different ones:
Complete, High Milage and Concentrate.
Which one are you using?
Thanks
ChronciallyChronic
Central Florida
2024 Ford Ranger Lariat
Thanks
No need for the High Mileage variant, unless you already have 80k+ miles on the truck.
Which engine do you have?
ChronciallyChronic
Central Florida
If you have a '24 (before the GDI was changed) keep in mind the fuel additives will work on the injectors only, it will not do anything for the intakes since this engine is a GDI engine without an injector above the intake valve.
I have a '24 with the 2.3 and am planning on having the intakes cleaned at 50k miles to address carbon build up that will be there.
Trimjb
Tennessee
2024 Ranger FX4
It is a 2024. When did they change GDI?
Trimjb
Tennessee
2024 Ranger FX4
Tier 1 fuels scarce?
So, no Mobil, Exxon, Chevron, or Texaco near you?
No, closest Chevron is 39 miles, Shell 13 miles, Costco 45 miles. No Texaco or Mobil.
Mostly Circle.K, Citgo, Murphy and a few other non Tier stations.
I just saw Citgo is Top Tier rated? The You Tube video didn't have much good to say about it.
It is a Venezuela based company.
There is a Sinclair that opened up not long ago. Looks like it might be Tier gas. I don't know much about Sinclair gas.
I'd bet they wanted to use up their stock of the regular DI engines first before the switch.
maybe but all the 25. 2.3s are the new engine, afaik
and production on the 25s was slow to start
possibly they wanted to get rid of the 24s
I think in 26 ford might finally hit their stride on ranger production.
I personally think ford would be smart to limit rangers changes for 2027. Maybe add some different trims and pull some stuff off the Australian version To limit production line disruption.
there are rumors of a possible bronco pickup
And ford is supposed to be producing some type of built ford tough affordable truck for 2029.
although I suspect that will be more like a maverick built with a streamlined assembly system resembling how teslas are built.
