Under-torqued Lug Nuts
TractorFixer
Iowa
While doing my first tire rotation at 5k miles, I noticed the lug nuts didn't seem to be overly tight. My digital torque wrench confirmed the break-away torque was consistently around 70 ft-lbs. The lug nut torque spec in the owners manual is 100 ft-lbs.
I probably should have checked them before now, may not be a bad idea to check yours.
To my knowledge, the wheels haven't been off since it left the factory.
ADVNTURR
Cleveland, OH
Breakaway torque isn't necessarily a great indicator of what the original dynamically set torque was, but that does sound low.
Thanks for the heads-up/reminder though, I'm going to be doing a big tow with mine in a couple weeks and I should probably double check stuff like that.
maxxvito
Adam
Minnesota
2021 F-150 RMT Overland
I called Ford Service to find out what the torque specs are, they said 150
Fred
Doesn’t 100 seem kinda low?
Not really. It's an M12 lug nut. They're typically around 100 ft/lbs.
My Lincoln has M14 lug nuts which are 154 ft/lbs.
I checked the torque on my Ranger last night. The majority were at 100 ft/lbs.
A few were just under that
NASSTY
ME
Mine seemed a bit under torqued when I removed my wheels.
ZilWin
Las Vegas
2024 Ford Ranger XLT 4x4
100 seems pretty standard on most vehicles. I've seen it as high as 120 ft lbs on my SL550 Benz but the tires had a Y speed rating. My 2007 Tacoma is 83 ft lbs. Never had an issue in 17 years. Dismiss the dealer's opinion, torque them equally to mfg Spec and you can't go wrong.
jeffers
Jeffrey
Nevada
2024 Ranger FX4, Mk7 GTI
I noticed the same thing, they might have been torqued to spec but they didn't seem like they were cranked on there. Like I said it might be right, people tend to crank stuff on way past torque spec.
jeffers
Jeffrey
Nevada
The problem comes when mechanics put your wheels on with impact wrenches. Its fast and convenient but they can really over torque them.
ZilWin
Las Vegas
Your right but they're not supposed to do that. Even Discount Tire ends with a torque wrench.
jeffers
Jeffrey
Nevada
Well you might want to say Discount Tire ends with a torque wrench.
2018
Corvette, '24 Ranger
Per the 2025 Ranger owner manual
Bolt Size lb.ft (Nm)1
M12 x 1.5 100 lb.ft (135 Nm)
boraxman
Santa Clarita, Ca. USA
Had over and under on mine.. All 100 now after first rotation.
BriSco
'24 Ranger XLT, 2.7L V6
Still they are usually too tight. When tighted to 250 ft-lbs with the impact gun, a torque wrench will still click at 150 ft-lbs setting.
