Window Feature Missing on ‘24 Raptor Ranger - Bring down all 4 via FOB
TheRealSasquatch
Bronco
My Bronco didn’t have that feature but I enabled it with Forscan. I will have to see if I can find it for my 24 RR.
quickstang1
Cypress
For people missing the window function. Did your Ranger Raptor have the recall done for the driver/passenger windows? Mine has a recall for window modules to be updated. I'm wondering if the recall fix eliminates the window from touch screen.
This came up a couple of months ago and that was the conclusion was after the recall it no longer works. My RR has the feature missing as well.
My Lariat had the recall done and I still have it so the recall didn't remove it.
Joejr
Joe
West Chester PA
I'm getting my truck inspectedand recall done on Thursday. I guess mine will no longer work after.
iBrad81
Brad
Cleveland Oh
Dont think it has anything to do with the recall. I am missing the feature built 8/24 also and no recall for windows
Raptortugal
Portugal
Ranger Raptor 6g
The "Global Window Close" and "Global Window Open" switches can be activated with forscan in APIM.
This allows you to temporarily disable opening or closing : especially accidental opening when the fob is pressed in the pocket.
Just checked my truck screen. I have window listed on screen.
T-Rev
I've had the window recall done. Had the feature before and still have it after.
Massman
Ed
MA
2024 Ranger Lariat
I didn't have a recall, but now I understand what the service manager meant when he said they checked the window functions several times. He also said they know my Lariat has the feature because it shows it on the windows. I never notice that before.
Massman
Ed
MA
2024 Ranger Lariat
Received the letter from my dealer regarding my window issue. In short, Ford states that some Ranger and Nautilus vehicles have this issue. The summary from Ford reads: "refer to workshop manual Section 501-11 for normal diagnosis. If this does not resolve the issue, inform customer that Ford is currently working on a solution." On the write up from the dealer it stated a couple of things I found interesting. While preforming the above diagnosis, the tech found updates for DDM and PDM. Tech performed both updates. After updates window feature still failed to work and then threw the following codes: B14DB, B14DC which were set in headlight control module. Tech had to perform SSM3175 in order to correct this new issue and codes. Tech also notes driver's window indicates the truck has this feature. I have no idea what those codes mean and would have asked had I been given the report prior to leaving. I will say I am impressed with my dealer following through as promised.
