Wiring Grill Lights to Operate with DRLs
MAV
Arkansas
During the amber DRL install, I also installed Signature Lux's amber grill lights. They look and work good, but for the sake of time, I wired them to my AUX1 switch. The switch stays on, so they're on when the truck is on, but I would like to wire them to something that turns them on when the DRLs are activated. This occurs when you unlock the truck, have approach lighting turned on, etc.
Below is a picture and a wiring diagram of the left headlight connector:
Ford Ranger Wiring Grill Lights to Operate with DRLs 1750186226147-w6
Ford Ranger Wiring Grill Lights to Operate with DRLs 1750186169627-rs
I was tempted to tap into pin 3 to feed the grill lights, but I know that DRLs are dimmed in certain circumstances by PWM from the BCM, and although I didn't test, I think I read somewhere that they don't operate on a full 12V circuit.
So the next best thing would be to tap pin 20 which is the side marker light, but those aren't always on.
Are any of you lighting gurus using some other circuit somewhere to have your grill lights on with the rest of the lighting system, or is everyone pretty much using AUX switches?
Sauce
Northeast
2025 Ranger XLT FX4
Im interested to know the answer too. As another option could you use a multimeter to figure out a fuse in the engine bay and fusetap them?
Hedder
Keith
Arnold, Md
2024 Ranger Raptor. 2022 BMW K1600 MC. 2003 Harley Davidson CVO Deuce
I wired my grill lights to my side marker lights, and then used Forscan to enable the side markers to come on with the DRLs. It works great. I also wired the amber backlight portion of my fogs to the same circuit . It looks really good when you unlock the truck.?
MAV
MAV
Arkansas
Perfect! I guess I didn’t know there was an option in Forscan to tie the side markers to the DRLs. I’ll look that up. Thanks!
Tobias
Tobias
Orting, WA
Warehouse Associate
MAV
MAV
Arkansas
I believe this setting in Forscan does enable the park lamps to come on with the DRLs, but that also means that the rear park lamps (tail lights) are on as well. Is that the case with your settings?
Hedder
Keith
Arnold, Md
No, the setting I used just enabled the side markers. I did no know that 5her3 was @nother setting that enabled the parking lamps too.
MAV
MAV
Arkansas
Which setting/code did you use?
Hedder
Keith
Arnold, Md
I can’t recall the exact location in the modules, but if you look under Side Markers, you will have an option to enable with DRLs.
iBrad81
Brad
Cleveland Oh
I also wired them to my side marker lamps but didn’t change anything, it now acts just like the big Raptor, the 3 grill lights only come on when the headlamps are on and DRL’s dim. Otherwise it’s just the DRL on full
arandazz
Andrew
PA
2024 Raptor Ranger
I installed my signature lux grille lights. Powered them with the SPV headlight harness. They came out great.
Lux Led
SPV Headlight Harness
The SPV harness came with the tap on pin 3 (DRL@5v), I switched it to pin 9 (marker lights@12v). My marker lights are always on along with the grille lights.
Ford Ranger Wiring Grill Lights to Operate with DRLs IMG_1932
Mattsraptor 2025
Europe
2024 Raptor
I’m also looking to wire the grille LED’s to the DRL’s by tapping in.
How would the LED’s be affected when the DRL’s dim down when switching on the main lights/dipped beams?
Unfortunately EU Raptors don’t come with side marker lights and I can’t seem to find a plug & play harness.
Mattsraptor 2025
Europe
2024 Raptor
Hello everyone I just got done installing the Signature luxe full grill on my RR this is the plug and play harness i used for the Raptor lights to be wired in with the DRL's. It works awesome
https://specialtyperformanceparts.com/products/spv-parts-harness-system-2024-2025-ranger-raptor-led-headlight-parking-headlig 20250611_144325.jpg ht-connector-adapter-powers-backlights?_pos=1&_sid=a5ecf6140&_ss=r
How did you connect the grille LED’s to this harness?
Did you have to remove the connector from the SPV harness or was it compatible with the fitting on the LED harness?
Cheers.
Sauce
Northeast
2025 Ranger XLT FX4
Cheers.
I wired mine the same way and hadn't noticed that, but I will double check and get back to you. If it dims, it doesn't dim much. With this wiring, I DO recommend turning off the wink with forscan though otherwise the drl will go off with your turn signal.
